2000 2.7T: Turbo went out! Help!!!
Old Jan 7, 2006 | 09:07 PM
slee22's Avatar
Default RE: 2000 2.7T: Turbo went out! Help!!!
Isn't there a 7 year/70,000 mile factory warranty on the turbos? I thought I had read that somewhere...
Old Jan 9, 2006 | 12:13 PM
misko's Avatar
service CD says it is a must to replace both turbos if one has failed.
but I agree if the other tests out fine save the money,but make sure its
tested
Old Jan 9, 2006 | 02:55 PM
Big Tone's Avatar
ORIGINAL: slee22
I am not aware of that. If you could find out where you read that let me know please!
Old Jan 9, 2006 | 02:57 PM
Big Tone's Avatar
ORIGINAL: Kievskiy
ok, about tie rod.....Jack up the car and check the rubber on both tie rods and try to shake the wheel, you 'll be able to see if the wheel sits tight or not.
turbos....sounds like it really went out on you... i only hope that its not the engine itself only turbo, how is the idling? even when turbo is broken the car should idle ok....what else....try to get as many opinions localy as you can.This is a very low miles car.....stock Audi turbos goes more than 100xxx miles 100%....yours was probably changed before.... i have 2.7t 6speed manual, with 89xxx miles, everything stock , went to audi dealer, they said turbos are stock no record on replacement...if you have Tip your turbos should be better then manual car, something was done to your car before, driving without oil/coolant, etc.
It idles fine.
Old Jan 9, 2006 | 03:00 PM
Big Tone's Avatar
ORIGINAL: mastvadz71
if you decide to repear the car ,replace both turbos,do not make a mistake doing only one.
We are replacing both. One is gone and the other is on the way out according to Audi. Now the issue we have is getting the dealer where we bought the car to give us a written estimate, because the amount they gave us over the phone for what it would cost for parts is about $1700 more than the written estimate from Audi.
Old Jan 9, 2006 | 04:42 PM
ecartoys's Avatar
Big Tone,
If you are able to ask them to do the job by providing the turbos yourself we will sell you the K04 upgrades at cost. It should still be cheaper than what the dealer wants for the stock turbos. On the stock turbos we only have the right side in stock so can't help you there.
eCarToys
Old Jan 9, 2006 | 06:43 PM
Kievskiy's Avatar
when they will change your turbo's ask them that you want to keep the old parts, this way you will be able to see what really happened, and if its not hard , please post some pictures. Good luck.
Old Jan 9, 2006 | 09:24 PM
  #18
ecartoys's Avatar
Big Tone,
Forgot to mention, the K04 Upgraded Turbos I quoted you are from the RS4 so they are direct bolt on.
Good luck.
David
eCarToys
Old Jan 10, 2006 | 12:07 AM
  #19
misko's Avatar
hereTurbocharger, removing and installing
Observe rules for cleanliness Page 21-8 .
Note:
Turbochargers must be replaced in pairs. Manufacturing tolerances may prevent matched operation.
All hose connections are secured with clips.
Charge air system must be free of leaks.
Replace self-locking nuts.
Replace all seals and gaskets
- Remove engine Page 10-2 .
this is from the repair CD
Old Jan 10, 2006 | 10:14 AM
  #20
kakarot's Avatar
also you can take the turbos off and rechip. then you will have regular V6 :-(
a bit of a hasle but cheap.
