2000 A6 2.7T shakes hard
Old May 19, 2011 | 10:00 AM
obujdei's Avatar
Unhappy 2000 A6 2.7T shakes hard
Hello,
I have a 2000 A6 2.7T with 137,000 miles. My car is running very rough. The car literally bumps up and down (from the motor).
I had it scanned and the codes came up as cylinder 1 and 5 are misfiring. I was recommended to change the coils, spark plugs, and/or run fuel injector cleaner, get new injectors.
Any ideas? Thank you so much,
Old May 20, 2011 | 07:41 AM
bob martin's Avatar
Start with spark plugs. Move coils around to see if the problem follows particular coils then replace them. Replace the ignitors on top of the air box. Run SeaFoam through your intake (might want to do this first, actually).
Bob
Old May 21, 2011 | 11:43 PM
ATSAutomotive's Avatar
Personally I would swap coils first, to see if the misfires follow the coil. Then check/change spark plugs. Check/Change ignition control modules on air box. Report back after that order.
Old May 24, 2011 | 05:56 PM
audiudo's Avatar
Had a similiar problem a week ago. It was my coilpacks. Changed them along with my plugs and its good to go.
chance21021
Aug 25, 2012 12:57 AM
rjsanders81
Aug 20, 2010 07:04 PM
PRican1.8T
Mar 20, 2008 05:22 PM
nickysteveo
May 31, 2007 11:05 PM
Audi PA 0u812
Mar 14, 2004 11:35 AM
