2000 a6 2.8 oil pressure
Old Nov 22, 2007 | 12:34 AM
frankinstyn's Avatar
Default 2000 a6 2.8 oil pressure
So I've purchased this wonderful car and thoroughly enjoy driving it. It has 90,000 miles on it, is as tight as it was new and shifts beautifully.
There is of coarse a concern. The oil pressure does not seem as high as it should be. I don't have a gauge of unfortunately. When I drive like a normal human being everything is fine. No noise. Plenty of power. Perfect. It is when I really push it that there is a problem. With it under hard acceleration in first, second and third I will hear the slight sound of ticking from the lifters. Only when between 3000 and 4500 rpm. Still drives as should. Plenty of acceleration and no hesitation.
I have replaced the oil (and filter) with Elf Excellium NF-LDX 5W40 full synthedic (autohouse az) but it made no difference.
My first though (as I am a licensed advanced diesel mechanic) is that the oil pump is not pumping as it should or that there is a cavitation in the oil beneith the pump inlet due to the amount of oil being pumped.
So does anyone else have this same issue? Is there a general solution or do I need to replace the pump and see how it goes from there?
I'm not afraid of doing the work as these little engines are quite fun to work on but I still don't want to replace perfectly good parts.
Pump price isn't all that bad though...
http://www.drivewire.com/partr...lpump
Old Nov 24, 2007 | 02:17 PM
dankhound's Avatar
Default RE: 2000 a6 2.8 oil pressure
First thing i would do is get a gauge on the oil. That motor doesnt usually have oil pressure issues. The noise may be coming from somewhere else.
Festus
Jul 22, 2015 07:13 PM
rchachi
Sep 19, 2012 01:10 AM
yyzyyz
Jul 24, 2012 05:26 PM
breeze.12
Mar 14, 2007 11:31 PM
breeze.12
Mar 14, 2007 11:16 AM
