2000 A6 4.2 Quattro - Intake Manifold Actuator Seized *Open*??
One might utilize a dyno to fine tune the engine with IMT - Intake manifold tuning.
Otherwise - only your wallet will have a difference.
One could look at:
http://www.pvv.org/~shane/stasj/pics...g%20system.pdf
One could look at:
Thank you everyone for your help and input. The posted photos were really helpful, too. Here's what I've pieced together. I had a disconnected vac line (one of the connectors had snapped in two). I replaced that. I think I could stand to replace all the vac lines, but I didn't see any other blatant leaks. The two manifold arms are stuck in place, but they aren't stuck in the "open" position like I thought. The photos posted in this thread earlier helped me to determine that. I think I must have been thinking about the spring backwards.
As described earlier, the driver's side linkage arm is no more - it's not even there. From my understanding and from the videos of the whole deal in action, it appears that both valves are supposed to be inflated when the engine is off, pushing those manifold arms against their springs. When you turn the engine on, both valves should be "sucked" in, letting the manifold arms go back to rest. I've turned on the A6, let it idle for about five minutes, then I've revved it up (in park, not neutral) to 5000+ RPMs. I can see the driver's side valve (the disconnected one) move just a hair, but it does not inflate. That tells me I must have a vacuum leak somewhere else that I haven't found yet. Please correct me if I'm wrong.
I seem to have several problems happening simultaneously. My plan of action (reasonable?):
1) Follow the guides to remove the manifold actuators so that I can clean/tune them. This apparently needs to be done regardless of any other problems as both arms are stuck and won't move by hand pressure.
2) While I'm taking care of (1), go ahead and replace the vac lines. I'm not sure about what else operates on the vac system, but I thought for some reason the intake manifold setup was segregated by check valves or something similar, so that if one system elsewhere in the vehicle failed not every vac-based system would fail as well. Shouldn't I see the vac chamber (I believe that's what that blue kong-dog-toy looking object is in the left front of the vehicle?) compress/decompress with engine activity?
3) Buy a new pair of linkage arms (from gruvenparts.com, I'm assuming).
I know I need those manifold arms freed. I also know that if my valves aren't inflating/deflating as they should, the link arms will do no good and I may even snap off the plastic manifold arms. Does this all sound reasonable?
I think the change over valve actuates at 4200 RPM. You should actuate them by connecting a vacuum pump to existing lines after the solenoid switch.
Changing all of the vac lines is cheap. Go to www.ecstuning.com and order the oem braided tube. Then you will need about 2' or so of slightly larger tube (I used washer line from Advance) for the secondary air valves on the back. ECS may have some larger tubing I would suggest that instead of washer line.
Keep in mind the vacuum system stems from 1 line so any leaks along the way will damper the performance. That's why it's good to check your parts with the Vac pump first. You should always try to prove the part is broken before you replace it.
I'm new to this site. I have an 04 A8 and there is a noise coming from the top rear of the engine. I was told it is a intake manifold actuator. The sound is similar to an electric motor turning a bad gear. Does any of this make sense? The car is still running fine. Also, about a week ago, I started smelling oil burning. There are no leaks on the ground, so I am assuming it is a valve cover gasket. Do you have any suggestions?
Are those valves controlled by vacuum lines and have you tried actuating the valves and solenoids other than by hand.
As far as the knock sensor goes. Just wondering what is happening that makes you think it's bad. Audi's are so prone to misfires and those sensors are fairly simple.
Better question. Is this your first Audi? and have you performed any work on it yet? If your just starting out we can walk you through service items that you need to do that may resolve a lot of the issues your having.
Airwolf
Dec 24, 2011 10:19 PM
gabeguimaraes
May 22, 2009 04:46 PM
