2000 A6 auto won't shift into gear
Old Dec 14, 2010 | 08:27 PM
PeteMI's Avatar
Post 2000 A6 auto won't shift into gear
Hi,
My parents have a 2000 A6 with an auto transmission. They live in New York and I live in Michigan. They tell me they have a problem getting the car to shift into gear. They say that there is a red light symbol on the center console on the left hand side that comes on when they start the car. It looks like a foot on a brake. They say that if that red light is on, they can't get it in gear. after the car sits for a while or they trun it on and off, they can usually get the light to go off. I am assuming that this should be something that a mechanic could diagnose easily, but that must not be the case. Does anyone know what this light is indicating and are there any suggestions on how to fix it ?
Old Dec 15, 2010 | 08:37 AM
oldmots's Avatar
This is a warning light to remind the driver to step on the brake before shifting into gear. It is perfectly normal. It should go out once the car is in gear. If the brake is not applied, the car will not shift into gear.
Old Dec 15, 2010 | 08:58 AM
jhuffman's Avatar
if they are pressing the brake, the brake pedal sensor might either need adjustment or replacement
Old Dec 15, 2010 | 06:18 PM
PeteMI's Avatar
Post
I already verified that they are stepping on the brake, so I am guessing that there is an adjustment that has to be done to the sensor or it has to be replaced. The thing that surprised me is that our local Audi dealer could not figure this out.
Thanks for the response.
Old Dec 10, 2014 | 06:49 AM
Tenson's Avatar
I have 2000 Audi A6,i have same problem as yours but just want to know if i buy a new padal sensor or brake switch will sorve this problem?,i can not shift into gear and there is a red light symbol on the centre console on the left hand side that comes on when i start the car ,it looks like a foot on the brake,if the the red light is flashing i cant get it into gear,
so far i try to change gearbox oil,and the problem still there...i need help how to fix this problem please.
and its failing to drive on uphill,
and sometimes when i disconect the terminal from battery over night the light goes off till the car is hot
Ron Sweeney
Jun 12, 2011 04:10 PM
skyz
Jun 20, 2009 12:22 AM
GBman
Aug 20, 2008 06:15 AM
aragorn65
Feb 17, 2008 08:24 PM
AndyMann
Jan 9, 2006 01:10 PM
