2000 audi a6 2.7t
Old May 19, 2011 | 10:11 PM
mgv1992's Avatar
Default 2000 audi a6 2.7t
HI I have a 2000 audi a6 2.7t quattro all wheel drive with 142,000 miles it was shaking very violently at any speed especially at idol so I took it to my mechanic and he said that my valves lost compression and this is the cause of my shaking any suggestions on how to fix this problem?
Old May 20, 2011 | 07:14 AM
bob martin's Avatar
Trade your car in. Easy fix. Quick, too.
Old May 21, 2011 | 11:48 PM
ATSAutomotive's Avatar
Is the CEL blinking? Do you have any codes in the system. You need to give us some more information in order to accurately diagnose and help you.
Old May 30, 2011 | 06:48 PM
Cronus's Avatar
Need error codes!
Off the top of my head it may be leaks in your vacuum lines or misfires due to flooded spark plugs. Issues with the lines and bad spark plugs can produce similar dysfunction.
Check your Engine Control Module fuse. I had similar issues when I decided to pop open my dash fuses and found the little guy blown. If it is really this bad you must have a check engine light.
gilliethakidd
Jun 18, 2012 07:11 AM
nukauto
Feb 2, 2008 11:02 PM
KAYAudi
Jan 17, 2005 09:04 PM
