2001 A6 Quattro Transmission sliping help.
OK.. My 2001 A6 runs almost normal when first starting up. As it warm up it starts to slip in and out of gear when going into second gear. In the higher gears the car runs great. If I accelerate slowly from a stop the transmission is smoother and I can drive it for maybe twenty miles or so before it is slipping tooo bad to drive. If I don't drive it slow and smooth from a stop it slams into gear making the car jump and NDR123 lights up.
So far I changed the trans fluid and filter. No change
I also bought a new TCU and did a Throttle Body adaptation, and the Trans-Throttle adaptation. No change.
Does anyone have any other ideas?
I just need the car to run for about six more months because I am deploying over seas. Please help me anyone.
Thanks...
Thanks...
Ordered a trans service kit from blauparts.com. It came with a new filter and seal and six quarts of fluid. when i changed the fluid only used about two and a half quarts. Im actually getting the level double checked by someone today. Thanks for your help. please stick with me. Thx.
This is the only info I have on the car. Is this what you needed?
Tuesday,22,June,2010,18:52:45:14019
VCDS Version: Beta 10.3.0
Data version: 20100324
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 34 35 36 37 45 55 56 57 65 67 75
76 77
VIN:
Address 01: Engine Labels: None
Part No: 4D0 907 560 AE
Component: 4.2l V8/5V G 0003
Coding: 07752
Shop #: WSC 02325
1 Fault Found:
16711 - Knock Sensor 1 (G61): Signal too Low
P0327 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01L-927-156.lbl
Part No: 4B0 927 156 CT
Component: AG5 01L 4.2l5V USA 0708
Coding: 00002
Shop #: WSC 02325
1 Fault Found:
17116 - Gear 2: Incorrect Ratio
P0732 - 35-10 - - - Intermittent
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 8D0 907 389 E
Component: ABS/ESP allrad D56
Coding: 06397
Shop #: WSC 02325
No fault code found.
Address 06: Seat Mem. Pass Labels: None
Part No: 4B0 959 760 C
Component: Sitzmemory R1 BF 0102
Coding: 00003
Shop #: WSC 00000
1 Fault Found:
01731 - Switch for Seat Height Front Pass. Seat (E65); Down
28-10 - Short to Plus - Intermittent
Address 08: Auto HVAC Labels: 4B0-820-043-MY1.lbl
Part No: 4B0 820 043 AH
Component: A6-Klimavollautomat D65
Coding: 00180
Shop #: WSC 02325
Address 15: Airbags Labels: 4B0-959-655-AI8.lbl
Part No: 4B0 959 655 F
Component: Airbag Front+Kopf 2002
Coding: 00305
Shop #: WSC 02325
Address 16: Steering wheel Labels: 4B0-907-487.lbl
Part No: 4B0 907 487 D
Component: Lenkradelektronik D03
Coding: 00102
Shop #: WSC 65535
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 981 GX
Component: C5-KOMBIINSTR. VDO D17
Coding: 03283
Shop #: WSC 07308
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 J
Component: Central Lock/Alarm D34
Coding: 15885
Shop #: WSC 20211
3 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01560 - Passenger Door
59-00 - Can't Unlock
01561 - Left Rear Door
59-10 - Can't Unlock - Intermittent
Address 36: Seat Mem. Drvr Labels: None
Part No: 4B0 959 760 B
Component: Sitzmemory R1 F 0101
Coding: 00001
Shop #: WSC 00000
Address 45: Inter. Monitor Labels: None
Part No: 4B0 951 178 A
Component: Innenraumueberw. D04
Coding: 00101
Shop #: WSC 02325
Address 55: Xenon Range Labels: 4B0-907-357-DYN.lbl
Part No: 4B0 907 357 C
Component: dynamische LWR D05
Coding: 00020
Shop #: WSC 02325
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 4B0 035 195 A
Component: Radio D00
Coding: 00114
Shop #: WSC 02325
1 Fault Found:
65535 - Internal Control Module Memory Error
00-00 - -
End ---------------------------------------------------------------------
76 77
VIN:
Coding: 07752
Shop #: WSC 02325
1 Fault Found:
Coding: 00002
Shop #: WSC 02325
1 Fault Found:
Coding: 06397
Shop #: WSC 02325
Coding: 00003
Shop #: WSC 00000
1 Fault Found:
Coding: 00180
Shop #: WSC 02325
Coding: 00305
Shop #: WSC 02325
Coding: 00102
Shop #: WSC 65535
Coding: 03283
Shop #: WSC 07308
Coding: 15885
Shop #: WSC 20211
3 Faults Found:
35-00 - -
Coding: 00001
Shop #: WSC 00000
Coding: 00101
Shop #: WSC 02325
Coding: 00020
Shop #: WSC 02325
Coding: 00114
Shop #: WSC 02325
1 Fault Found:
00-00 - -
You have 4.2
Mileage - unknown- should be read by the scanner!
With your transmission =>
"only used about two and a half quarts" is completely WRONG!
If 2.5q came off with oil pan down - your transmission could be beyound the point of revival!
If 2.5q went in after proper drainage - you have no idea how to fill in the transmission.
Either way - get professional help if there is still room to save that transmission.
Audi or ZF will sell you a rebuilt transmission (ZF 24 HP ) for ~$6500.
Sorry,
Sorry,
http://www.blauparts.com/audi/audi_f...nsmissionfluid
I used the above instructions. and i found better ones here.
http://www.audipages.com/Tech_Articl...servicing.html
I'm going to give the fluid change another go. Do these instructions look OK to you?
I bought some extra like it said. I just saved what was left over. The heat is what is causing the problem. It cooled down to 80 degrees last night and the car drove fine till it heated up. Does anyone know what the normal temperature of the transmission fluid is during operation? I can monitor this with the VAGCOM can transmission cooling lines fail? This sucks.. No one around here deals with Audi transmissions except for the dealer.
a41.8Tblk
Oct 18, 2011 04:57 PM
01l927156lbl, 156, 2001, 258, 3510, 4b0, 927, 962, audi, intermittent, p0732, quattro, repair, transmission, vdo
