(2001) Audi A6 2.7T Oil - Pento High Performance II 5W40 Engine Oil
Old Aug 30, 2010 | 06:47 AM
corpses3's Avatar
Default (2001) Audi A6 2.7T Oil - Pento High Performance II 5W40 Engine Oil
Is this a good oil for my 2.7T A6?
Will bring it to my local mechanic to change it (for free), so thats why I want to get an Oil KIT.
Is the Pento High Performance II 5W40 any good for my car? Should I get something else? I do about 2000 city miles a month, and car has already 93000 miles on it.
Please provide links from e-tailers if I could get it cheaper from somewhere else, looking to place an order on 8/31. Looking for somewhat bang for the buck
Local Jiffy Lube charges 90$ for an oil change on this model.
Thanks.
Old Aug 30, 2010 | 11:24 AM
ppgoal's Avatar
It should be ok in the summer if it's a synthetic. I would recommend 0W-40 for the winter. I've been running Mobil1 0W-40 since I bought my A6 (as did the previous owner) and it's now at 176k miles with original turbos.
Old Aug 30, 2010 | 11:46 AM
hxgaser's Avatar
You can get Mobil or Castrol Syntec from local supplier for cheaper than that.
Old Aug 30, 2010 | 11:58 AM
corpses3's Avatar
Please give exact model/specs of Castrol/Mobil. And which local supplier exactly, link me to retailer
Oil was previously changed 5000-6000 miles ago, by Jiffy Lube.
Note: Driving this in Chicago area, which means hot summers (almost gone now), and very cold winters.
Old Aug 30, 2010 | 01:12 PM
UberTeile's Avatar
I wouldn't hesitate to use Pentosyn motor oils if they were less expensive and/or easier to obtain. I'll stick w/the readily available Castrol Syntec 5w40 for the above mentioned reasons.
Old Aug 30, 2010 | 01:18 PM
UberTeile's Avatar
*delete*
Old Aug 30, 2010 | 01:23 PM
hxgaser's Avatar
Mobil 1 5w-40
Castrol Syntec 5w-40
Any store should carry them, including napa, kragen, and etc.
Old Aug 30, 2010 | 02:55 PM
jhuffman's Avatar
90$ to change oil on a car that you don't even need to lift off the ground? Why not just spend the money on good oil and do it yourself?
Old Aug 30, 2010 | 06:10 PM
corpses3's Avatar
I clearly stated the oil change will be free, except the materials (oil+filter).
Old Aug 30, 2010 | 08:24 PM
jhuffman's Avatar
I just can't believe that a quick lube place would charge that much. You can get new brakes put in for half that around Denver. I'm a DIY kind of guy, but are car labor rates really that high nowadays?
