2001 Audi A6 Trouble shooting PO420
Old Apr 24, 2008 | 07:30 PM
DoubleFace's Avatar
Default 2001 Audi A6 Trouble shooting PO420
Hi everyone,
I just purchased a 2001 Audi A6 2.8L v6 few weeks ago. This morning the check engine light came on. I took it to Autozone to scan it and this is what came up:
Catalyst efficiency Low-bank 1
Explanation: The oxygen sensors monitor the catalytic converters
ability to store oxygen.
The PCM has determined that the catalyst system efficiency for bank 1
is below the threshold for the current operating conditions. (Bank 1
identifies the location of cylinder #1 while bank 2 identifies the
cylinder on the opposite bank)
Probable causes:
1) Catalytic converter defective (possibly due to #2, #3, or #4)
2) Engine misfire or running condition
3) Large Vacuum leak
4) Engine oil leakage into exhaust-valve guide seals, piston rings
Somebody told me that there is a wayI canbypass the sensor so the check engine light can stay off...if there is a way, does anyone know how I can do it?
Thanks
Old Apr 24, 2008 | 09:50 PM
GDET09's Avatar
Default RE: 2001 Audi A6 Trouble shooting PO420
Yes there is but if there's a problem I defiantly wouldn't ignore it. Things will only get worse and you'll be dealing with more and larger problems.
Old Apr 24, 2008 | 09:57 PM
formulagigi's Avatar
why????????????????
Old Apr 25, 2008 | 01:46 AM
LeAudi19's Avatar
i would trust him, i ignored my check engine for maybe a month and o man......... some weird thing is happeneing , the car jerks when u press the gas, i feel scared of even taking it out of the garage
im just waiting to take it to get it checked and fixed now
Old Apr 25, 2008 | 03:06 PM
polancho's Avatar
Of course I agree with the restand Ithink that you should fix this to avoid future problems...butif youare not going to fix this anytime soon I wouldsuggestbuying avag-com scanner. You can buy a cheapvag-com cable on ebay oronefrom ross-tech. I think the ebay cable is only capable of reading and clearing codes (but in this case that would be what you are looking for). At least if you scan your car periodically you will know if the car is throwingany othercodes that are more serious and need immediate attention.
Ask an indi shop tolook at your carand they will be able to tell you if they can weld a universal catto your audi. This will be your cheapest option if you decide to replace the cat. The universal cat costs around $70. Good luck.
a4audia4
Dec 16, 2012 12:11 PM
jhowerter
Sep 6, 2012 08:23 PM
DoubleFace
Apr 26, 2008 11:22 AM
The Russian
Mar 6, 2007 02:26 AM
audiguy00
Mar 20, 2006 10:31 PM
