2002 A6 3.0 RPM surge
Old Sep 6, 2012 | 08:15 AM
  #21
tomo5011's Avatar
Default surge issue - related issue?
OK...one more issue I have noticed that may or may not be related to my surge problem.
At idle or in park (all running smooth) If I give the gas pendel a QUICK FAST tap the RPM quickly dips for a second to the point the engine almost dies then it recovers (all in about 1 second) This occurs every time I gib=ve it a quick tap. If I start out nice and smooth on the pedal it acts fine.
Also when I was going at like 50-60 mph with the cruise control on...everything runs good but if I again "tap" the gas pedal you can feel the engine shutter for a second again. This again happens every time I tape the pedal put if I smoothly get on the pedal to speed if ...all is good.
Old Sep 6, 2012 | 01:06 PM
  #22
Jackmup's Avatar
Ive seen this before
It was the throttle control module
I have a thread on cleaning my a8 and I know I have photos cleaning it
Its the electrical contacts
They are under a plastic cover on the side of the throttle body
You need to remove the cover and clean the contacts with a finger nail file
It is of the utmost importance that it be your wife's favorite one
Make sure you retention the contacts and apply dielectric grease to any terminals. Retention female terminals with a small pick and. Clean males with the file. You are loosing voltage through bad contacts
Pm me ill get you some photos when I'm at my desktop
It's not a bad job
Old Sep 7, 2012 | 07:59 AM
  #23
tomo5011's Avatar
Default trottle control
sure sounds like a good option to try...and this throttle control module is on the side of the trottle body...on a 3.0 ?
Old Sep 7, 2012 | 01:04 PM
  #24
Jackmup's Avatar
Yes it is and it sounds like your problem
Old Sep 3, 2018 | 11:46 PM
  #25
Tonymonolo's Avatar
so whats was the problem???
Kopper
Jun 9, 2013 02:15 PM
heatON19
Oct 22, 2012 12:52 PM
tomo5011
Aug 6, 2012 09:29 AM
dirtyguido
Aug 21, 2009 05:01 PM
Eric_C
Apr 18, 2009 08:18 PM
