2002 A6 A/C issue
Old May 19, 2006 | 02:06 PM
tartan37's Avatar
Default 2002 A6 A/C issue
Car was blowing warm air. Took it into shop to have refrigerant recharged. Dye was added to trace for leaks in system. Anyone else have this happen? Seems odd to have happen on a vehicle with 31,000 miles. Seems fine now, shop to check on 5/22 for leaks in system.
Old May 19, 2006 | 02:10 PM
techbod's Avatar
Default RE: 2002 A6 A/C issue
quite normal mate gasses leak through the pores of the metal 24/7 and millage doesn't count on A/C
Old May 19, 2006 | 02:12 PM
tartan37's Avatar
thanks
Old May 19, 2006 | 05:14 PM
jic534's Avatar
The a/c is a sealed system, the metal is not pores. If the refrigerant pressure is low or non-existant there is a leak or failure of one of the components.
Old May 20, 2006 | 01:22 PM
dankhound's Avatar
Seen this quite a few times. Im not sure exactly what the problem is but i think its a temperature dependant leak. It must leak out when its cold and parts tolerances change. Then when it gets hot you have no ac. But at that time there is no leak found.
Minigemi
Apr 25, 2014 05:26 PM
clfehlinger34
Sep 6, 2013 09:11 PM
SilverS8
Sep 23, 2010 06:51 PM
Berk0711
Jul 19, 2010 06:25 PM
andypA4
Dec 19, 2007 03:38 PM
