2002 A6 xenon ballast
Old Oct 13, 2005 | 03:43 AM
markcauthen's Avatar
Default 2002 A6 xenon ballast
I have a bad ballast in one of my xenon headlamps. Can I replace this myself? It looks like I'll have to remove the whole headlamp assembly to get to it. Any advice?
Thanks,
Mark
Old Oct 18, 2005 | 08:46 PM
teddybgame's Avatar
Default RE: 2002 A6 xenon ballast
yes, see my links below for my OEM HID upgrade for background. Are you sure it is not the HID bulb? Have you tried a new bulb to troubleshoot?
You can get one from ebay for about $100. Just make sure it is from an A6 from 1998-2004 (an A4 or A8 won't be the same; any allroad ballast will work to). Here is exactly what you need:
http://cgi.ebay.com/ebaymotors/AUDI-...spagenameZWDVW
You can use the other wiring from your old ballas in it's place. Yes, you will need to remove the entire headlight to replace it.
Good luck!
Old Aug 24, 2010 | 02:54 AM
command's Avatar
Default 202 A6 oem Xenon Ballast
Thanks,
Mark
A6 oem ballast ,fit under the headlamp .ballast like this.
BTW AUDI RS6 use ballast is same
Old Oct 19, 2010 | 05:17 PM
AUDIFIELD's Avatar
Default ballast or bulb ?
hi I have the 98 qttro but I know it's xenon. my lights both work (high and low) but there is no blue tint. so is that bulb wear or ballast wear?
thanks! also what are the replacements I see for around 25 each on e-bay with new ballast?
thanks...
Old Nov 19, 2010 | 01:05 AM
command's Avatar
Default about bulb blue
thanks...
if you need bulb ,only need change the bulb ,choose 6000k is good.
like this.
Old Dec 19, 2010 | 02:08 PM
histeel's Avatar
you can replace this ballast without removing the headlight, you will need to remove the inner fender and remove the 1 screw that holds the ballast in place you will need to bend the bracket out of the way and slide the ballast out. It is a huge pain in the *** to remove the screw but it is a lot easier then putting the lock carrier in service position. This does work on the passenger side i have not tried it on the drivers side but it should work also you would need to remove the washer reservoir on the drivers side.
vasol
Aug 19, 2013 02:49 AM
wutafobbb
B7 Models
May 16, 2013 11:59 AM
jefferskn
Mar 25, 2012 10:46 PM
tjaudi
B7 Models
Apr 8, 2011 12:58 PM
BLAZEDUPBEE
Jan 5, 2006 06:46 PM
