2002 Audi A6 Quattro Fault code PO741
Old Sep 18, 2007 | 08:35 PM
arrrgh's Avatar
Default 2002 Audi A6 Quattro Fault code PO741
Can anyone shed some light on this fault code? I have tracked down the TSB 320501 but only a summary which states torque convertor performance or solenoid valve stuck shut. The car runs fine and since mechanic cleared the code it has not come back. TSB also states no performance issue with this fault. New Torque convertor is $3,500 and up. Do I need to replace it or is this just a phantom code? Replacement is significant potion of the car's value. Any help would be apreciated.
Old Sep 18, 2007 | 11:49 PM
auditech79's Avatar
Default RE: 2002 Audi A6 Quattro Fault code PO741
The best you could hope for is the TCC doesn't get stuck again and cause a check engine light.
If it happens again the torque converter has to be replaced, end of story.
Leaving a faulty one in there is not healthy for the transmission.
silver a vier
Sep 17, 2011 03:04 PM
ssingh
Feb 10, 2011 08:03 AM
ssingh
Feb 10, 2011 07:59 AM
dqpb tturboeattrouattro
Apr 25, 2009 02:51 AM
jkor2003
Jan 26, 2009 10:26 AM
