2003 A6 3.0 ABS Light always on!!!
Old Aug 27, 2007 | 03:25 PM
stubird's Avatar
Default 2003 A6 3.0 ABS Light always on!!!
anyone having trouble with their ABS Light always being lit? I took it to the service folks and they couldn't find anything wrong with the brakes. But, 2 days later the light goes on again!! Between the windsheild wiper warning and the ABS I ge tplenty of yellow on my dashboard!!
Thoughts?
Old Aug 27, 2007 | 03:36 PM
techbod's Avatar
Default RE: 2003 A6 3.0 ABS Light always on!!!
sounds like a wheel sensor or just needs a clean up since its intermittent there will be a code stored but you need VAG to find out, if the ABS light is on the ABS is switched off and if its off then the system is reading ok and on so it does sound like the above + it might be a loose connection
Old Aug 27, 2007 | 03:53 PM
muphasta's Avatar
My ABS light was on for a while. I took it to the shop and I guess there is a switch or something in the brake pedal area that got stuck. It was a while ago, so I don't remember for sure. I think they just cleaned it up or out.
Sorry to be so vague, but it was a while ago.
Old Aug 27, 2007 | 04:01 PM
techbod's Avatar
ahh my appols there ( the light is on all the time ) not intermittent[:-]then there is a problem without doubt and probably a wheel sensor so how come they couldn't find a code? what software/tool did they use ( if any ) or did they just clear the code in the hope it wouldn't come back on, the latter sounds about right so get them to check it again and give you a read out of the fault codes
Old Aug 27, 2007 | 04:42 PM
Costner's Avatar
ORIGINAL: muphasta
I had the EXACT same issue - the ABS light was on a few times and then off and then on again. The sensor behind the brake peddle was faulty and when they hooked it up and looked at codes they traced it back to that switch. It cost a whopping $17 to replace, so it wasn't a big deal.
They gave me the old switch and I took it apart to see what the problem was - it turned out one of the contacts must have heated up and almost "welded" itself together. No big deal and it was an easy problem to correct.
agassi70
Feb 2, 2015 09:37 AM
nikuman
Mar 3, 2009 12:34 PM
bruiser12
Feb 15, 2009 05:38 PM
reachuarun
Jan 29, 2008 05:37 PM
