2004 A6 Hazard Switch Replacement
Old Mar 23, 2014 | 09:48 AM
TTeriffic's Avatar
Default 2004 A6 Hazard Switch Replacement
Hazard relay switch needs to be replaced. I got the old switch out as expected, only to find insufficient wire length to enable new switch to be attached to connector coming out of dash. Just no way that I can see to make this connection. Makes me think perhaps radio needs to be removed which would be insane. Any help appreciated, otherwise, I think it's off to the dealer. Thanks!
Old Mar 24, 2014 | 03:27 PM
TTeriffic's Avatar
Problem solved. Special right angled 'hook tool' is used to gain access via dummy switch opening to the left of the hazard switch opening. Tool pushes against the back of the female switch connector to keep it from collapsing inside the dash and allows the male-ended switch connector to be latched in place. Nothing 1-2" of extra connector wire would have eliminated! Better yet, dealer did not charge for the quick 5 minute fix.
lttlredA6
May 16, 2012 12:56 PM
kennny2004
Jun 11, 2011 09:39 PM
holdin16
Mar 1, 2010 01:13 AM
twenty8red
Oct 18, 2007 10:53 AM
rink2rink
Sep 1, 2006 01:55 AM
