2005 A6 4.2 Hard Start
Old Apr 21, 2013 | 09:22 AM
dleslie3183's Avatar
Default 2005 A6 4.2 Hard Start
I have recently started having a problem with cold starts. The engine will crank for longer than normal and then sometimes run rough when it starts.
Normal start is less than 3 seconds, so when I recognise that it is cranking too long, or is running rough when it starts, I immediately turn off the engine and restart. The restart is always completely normal (starts within 2 seconds and runs normally). When it first started this issue, I took it to my mechanic who did a major maintenance (plugs, filters, etc) and also added a can of 44K fuel system cleaner. But, the problem persists. Any ideas what this might be caused by? 2005 A6 4.2 Quattro 102,000miles.
Old Apr 23, 2013 | 10:45 AM
Nebuchadnezzar's Avatar
I have heard of dirty / old MAF sensors causing this issue. It may be worth the few bucks to get a can of MAF sensor cleaner and try it out.
I would be inclined to say it's just the starter, but you indicate that it's a rough idle after starting, so it seems like the ECU is trying to get the right mixture of fuel and air.
rccks96
Aug 29, 2023 08:58 PM
jlolsen34
Feb 11, 2011 06:34 PM
Skidog
Dec 10, 2010 09:08 AM
jaz6
Dec 7, 2008 01:00 AM
dapakattack
Nov 27, 2007 10:03 AM
