2005 A8L that has intermittent hard steering
Old Dec 9, 2010 | 10:48 PM
Skidog's Avatar
Default 2005 A8L that has intermittent hard steering
The car steers fine at slow speeds but gets stiffer and stiffer as you pick up speed. No codes shown when brought to the Audi Dealer. They drove and said it was normal but obviously didnt drive it fast enough. Im getting sore shoulders from road trips!
Old Dec 9, 2010 | 11:19 PM
silverd2's Avatar
"Servotronic" (speed sensitive steering) is supposed to decrease the boost with speed...easiest steering at stand still and increasingly stiffer at higher speeds. BUT sounds like it's overdoing it in your case...it's controlled by a removable valve on the steering rack (rack has to be removed to access it, though) that's electrically controlled by signals from the ECU.
The valve can be checked electrically from the valve's relay receptacle in the car. Bentley has the procedure and the dealer should know how to test it also.
Old Dec 9, 2010 | 11:35 PM
Skidog's Avatar
So it could possibly be the ICU, a relay or the valve itself, correct?
Old Dec 10, 2010 | 09:08 AM
silverd2's Avatar
Yes...first test would be simple electrical test at relay receptacle...that would (could) eliminate faulty valve...then relay itself, if good then signal from ECU. Not as likely, but theoretically possible would be rack or pump, BUT if you get full boost at idle..NOT likely a problem there.
audia4012.8Q
Sep 8, 2010 09:54 PM
billboos
May 1, 2009 12:10 PM
jaz6
Dec 7, 2008 01:00 AM
varsh
Jul 10, 2008 12:24 PM
