2005 A6 Cutout Issues
Old Apr 10, 2013 | 09:07 PM
kiteoregon's Avatar
Default 2005 A6 Cutout Issues
I know these problems are just about impossible to diagnose. The car has 171k and i don't know much about the PO history. I just picked the car up about 5 weeks ago. Sometimes when driving, usually in 4th or 5th the car will suddenly cut out and start lurching. As soon as i put in the clutch and rev the car it's fine. In both circumstances, i ended up pulling over revving the car without issue and there was no problem. I continued to drive for 15- 20 more minutes with no issues. Probably related to this, the other day the car just died at a stoplight. When trying to start it took a little longer and sputtered a but then it was fine.
I should also point out that both times the engine started to cut out the car was on a flat or headed down a gentle hill under light throttle pressure. I have had a CEL a couple times, but in these cases no CEL.
First i am thinking i would change the fuel filter, if that does not solve the problem, which i am guessing it won't i will start to look at the plugs, wires, coils etc. Is this the correct logic, or may i be missing something obvious?
Thanks
KO
Old Apr 10, 2013 | 10:56 PM
kiteoregon's Avatar
Update: the car had been sitting at my office for about the last 10 days. Today i decided i would drive it home. I made it about 100 yards and it really started running like crap and finally died. I was able to get it started and get back to the parking lot. I also noticed when i pulled out of the parking lot it sounds like there are gallons of water in the body or trapped behind the dash. I also have a very wet passenger side carpet. I believe i saw somewhere that there is some electrical in the floor boards on the passenger side. I am guessing that the water is part of the problem. Is this a plugged sun roof drain? Would this cause the car to run poorly?
When i purchased the car we had about 2 weeks without rain and the car ran great.
This car is located in portland or, we get our share of rain, especially in march and april.
Thanks.
KO.
Audilou179
Sep 14, 2009 09:38 AM
tdblanchard
May 30, 2008 06:13 AM
superslow
Jul 16, 2007 01:03 PM
b.hasz
Feb 28, 2007 03:05 AM
rhynolite
Oct 27, 2006 04:26 AM
