2005 Audi A6 A/C blows hot air, evaporator temperature sensor replacement
Old Mar 28, 2017 | 07:06 PM
agcee2014's Avatar
I am having the very same issues as everyone here the 2005 Audi A6 3.2 blows hot air in the sid vents while a/c is on and center vents blow cool air and the rear vents also blow hot air. What causes this issue and how can it be fixed and more importantly how much does it cost to fix?
Old Mar 29, 2017 | 01:31 AM
bonnie sacer's Avatar
sorry to hear that, maybe you can use computer read data and analysis about the fault.
Old Jul 4, 2017 | 03:34 PM
chrisjharris's Avatar
need help with this problem too. does anyone know what it could be.
Old Oct 5, 2018 | 08:13 AM
ThomasA6's Avatar
Default I am having this issue with my 3.2 2007 A6
Originally Posted by Kevin
Here is the link to my entire TSB library. Take a look in the HVAC section for the TSB you guys are looking for. Good luck.
Originally Posted by Sellvakumar
could you please share the TSB library link j have the same problem now
is there some that can forward the linknto the fix so that my wife still ride with.me in my car.....thank you thomas.bezanson@gmail.com
Old Nov 24, 2018 | 10:41 PM
Joe Bui's Avatar
It's is the 2 stainless steel solenoids under the hood by the coolant tank. You need to remove the cover and clean those stainless steel cathodes. They get corrosion and the magnetic field won't activate the coils when the temp sensor sends a signal leaving g them stuck shut with heat from the heator core. There are videos on YouTube. Minimal work to correct.
Old Jul 30, 2024 | 01:00 AM
JFAZ's Avatar
Default I'm having the same problem ! Help☹️
This is a known problem with the C6. Audi has issued a TSB setting forth the repair procedure. Send me a PM, with your e-mail address, reference the AC problem with the outer vents blowing hot air while the outer vents blow cold air, and I will e-mail you the TSB.
please send me the link too. jsaf67@yahoo.com
Many thanks
AdamTCB
Aug 3, 2009 07:22 PM
J.C.
Jul 5, 2008 09:52 AM
mbrookbank
Sep 5, 2007 08:08 PM
geno
Jan 7, 2007 09:35 AM
quattro/2.8
Sep 8, 2006 02:17 AM
