Sponsored by:
Sponsored by:
2006 A6 wagon. Where is the cabin filter and how do u change it?
Old 06-13-2010, 01:56 AM
wagonman36's Avatar
Default 2006 A6 wagon. Where is the cabin filter and how do u change it?
Does anyone no how to change the cabin air filter? I can't find it.
Thanks
Ron
Old 06-13-2010, 04:23 AM
roadrune's Avatar
It is behind the glove compartment....
Take that out, and you will see a small hatch on the A/C unit, remove the hatch and pull out one filter, then pull the second filter down and out.
Old 06-13-2010, 10:52 AM
wagonman36's Avatar
I saw the ac on the left, when I had the glove box out. I removed the vent to the floor in front of it but could not see any filter anywhere. I could see what I think is the condensor. It was a radiator looking thing. Any more thoughts?
Thanks
Ron
Old 06-13-2010, 01:35 PM
roadrune's Avatar
It's a small plastic-hatch fitted with one bolt at the bottom, and a hinge on top.
It's towards the front of the car, a bit high up and really awkward to get to....
You do not need to remove anything else then the glove-compartment...
Old 06-13-2010, 02:11 PM
auditech79's Avatar
You don't need to remove the glove cmopartment, just pull down the panel under the glove box. If its never been done you will have to rip the seal (tape basically) then you can reach up and remove the little plastic door thats in the way. Flip that out of the way and the filters are stacked on top of each other. Make sure to install the new filters in the correct direction.
Old 06-14-2010, 12:56 AM
JPJ2007's Avatar
Member
I'm guessing the sedan is the same way?
My 06 has 115k miles, It prolly needs replaced also.
Old 06-14-2010, 02:38 AM
roadrune's Avatar
Should be the same on both sedan and avant.
I wasn't aware it could be done without removing the glove compartment, but i believe it is easier if you do not know excatly where the hatch is....
I changed mine when the car had 110k Km on it, and it was needed.... Not the first time it was changed either, who ever did it the last time put them in the wrong way.
Old 06-24-2010, 11:03 AM
bigsnowdog's Avatar
What does wrong way mean? Are they directional in flow?
Old 06-24-2010, 08:42 PM
FingerLakes's Avatar
Same spot on a 03?
Old 06-25-2010, 05:45 AM
Kevin's Avatar
Thanks
Ron
Here is a link to a DIY 55K miles service, scroll down to the write up on replacing the cabin filter.
http://forums.audiworld.com/showthread.php?t=2760602
Quick Reply: 2006 A6 wagon. Where is the cabin filter and how do u change it?
