2009 LCI facelift MMI dead, cd changer ejects discs but screen dead, help needed plea
Subscribe
Jun 16, 2019 | 07:19 PM
Dear all,
I have got a 2009 C6 saloon LCI facelift with a cd unit which has two sd card slots in the glove box. After the MMI dead this unit still eject and take CD in which confused me.
I don’t think the car had sat nav as before the mmi dead it shows sat nav unavailable or something similar.
Also the Bluetooth wasn’t working when I got it. I have no idea it was faulty or not fitted by Audi as in 2009 among the first few facelift seems got basic MMI? Not sure...
My friend borrowed it from me for one day then upon return the mmi dead and so is the radio. The control buttons are all non illuminated. I’m not sure it was my friends fault or not as a while ago I had problems powering the radio up but somehow it came back on just fine so I did not bother.
This time it has completly dead, I tried to force reboot it by long pressing the three buttons but no joy.
Pulled all the fuses out and back in, still dead.
In the boot there is nothing to the left, only some fuses to the right.
Help needed please.
Please see the attached scan results, did an Optical Bus scan and to my suprise both modoules came back ok.......
However when I tried to get into moudle 56 there is no response..
Sorry if the scan results is too long. Please let me know if I can cut some unrelevant info out.
Many thanks.
Reply
Jun 16, 2019 | 07:20 PM
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
Sunday,16,June,2019,12:26:19:17052
Chassis Type: 4F (4F0)
Scan: 01 03 05 08 09 15 16 17 19 42 46 4F 52 53 55 56 5F 62 72
VIN: WAUZZZ4F19N041461 Mileage: 151860km/94361miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 1010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 1010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: Malfunction 1010
52-Door Elect, Pass. -- Status: Malfunction 1010
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: Sporadic communication error 1000
72-Door, Rear Right -- Status: Malfunction 0010
Address 01: Engine (J623-CAGB) Labels: 03L-906-022-CAG.clb
Part No SW: 03L 906 022 SB HW: 03L 906 022 FG
Component: R4 2.0l TDI H01 9978
Revision: 11H01--- Serial number:
Coding: 0105002C18072118
Shop #: WSC 53057 001 1048576
ASAM Dataset: EV_ECM20TDI03L906022SB A01007
ROD: EV_ECM20TDI03L906019AE.rod
VCID: 77FDF8D6CE8FD8A6A59-8022
1 Fault Found:
4699 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 6
Mileage: 151848 km
Date: 2008.08.13
Time: 00:01:30
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 AK HW: 4F0 614 517 AT
Component: ESP8 front H03 0060
Revision: 00000000 Serial number: 00000000000000
Coding: 0020855
Shop #: WSC 02325 785 00200
VCID: 6DD1DABE74D362764F5-8038
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 5
Reset counter: 99
Mileage: 151448 km
Time Indication: 0
Date: 2008.08.13
Time: 11:51:22
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x4282
Hex Value: 0x0024
Hex Value: 0x0195
Hex Value: 0x00FF
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 B HW: 4F0 905 852 D
Component: FBSAUDIC6 ELV H05 0100
Revision: 00H05000 Serial number: 10602601270337
Coding: 0000017
Shop #: WSC 02323 785 00200
VCID: 2541E29EECA39A36C75-8070
Subsystem 1 - Part No: 4F0 910 132 D
Component: FBSAUDIC6 EZS H03 0020
Subsystem 2 - Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H01 0040
2 Faults Found:
01332 - Door Control Module; Passenger Side (J387)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 97
Mileage: 151448 km
Time Indication: 0
Date: 2008.08.13
Time: 00:15:05
01333 - Door Control Module; Rear Left (J388)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 97
Mileage: 151448 km
Time Indication: 0
Date: 2008.08.13
Time: 00:15:05
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 B HW: 4F2 820 043 T
Component: KLIMABETAETIGUNGH30 0070
Revision: 00000073 Serial number: 00000030418950
Coding: 0001044
VCID: 1D31CA7EC4F352F69F5-8048
No fault code found.
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 N HW: 4F0 907 279
Component: ILM Fahrer H22 0320
Revision: 00000000 Serial number: 4F0907279
Coding: 0003121
Shop #: WSC 02256 785 00200
VCID: 34670FDA5779F3BE40B-8061
Subsystem 1 - Part No: 4F2 910 113 C Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H10 0040
Coding: 00056595
Shop #: WSC 02256
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00146221
Shop #: WSC 02256
3 Faults Found:
00456 - Control Module for Access and Start Control (J518)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 97
Mileage: 151448 km
Time Indication: 0
Date: 2008.08.13
Time: 00:06:00
00466 - Control Module for Steering Column Electronics (J527)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 97
Mileage: 151448 km
Time Indication: 0
Date: 2008.08.13
Time: 00:00:00
00910 - Indicator Lamp for Emergency Flashers (K6)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 2
Fault Frequency: 1
Reset counter: 97
Mileage: 151448 km
Time Indication: 0
Date: 2008.08.13
Time: 00:01:00
Address 15: Airbags (J234) Labels: 4F0-910-655-10.clb
Part No SW: 4F0 910 655 L HW: 4F0 959 655 E
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003CH003GCV8
Coding: 30314236303630303033554A305234463053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 306F03CA6B61CF9E243-8065
Crash sensor for side airbag; driver side:
Serial number: 3574SRB400008A50C285
Crash sensor for side airbag; passenger side:
Serial number: 3584SRB400008A5080F7
Crash sensor for side airbag; rear driver side:
Serial number: 35152RB402B838NMNJEJ
Crash sensor for side airbag; rear passenger side:
Serial number: 35252RB40357V8VHAJQ1
Crash sensor for front airbag; driver side:
Serial number: 3554NRB4000048FE1566
Crash sensor for front airbag; passenger side:
Serial number: 3564NRB400004911B27W
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0530
Revision: 00H05000 Serial number: 90025090230026
Coding: 0102041
VCID: 275DE89696AF8826F59-8072
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0030
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 99
Mileage: 151448 km
Time Indication: 0
Date: 2008.08.13
Time: 00:06:11
Address 17: Instruments (J285) Labels: 4F0-920-xxx-17.clb
Part No SW: 4F0 920 951 C HW: 4F0 920 951 C
Component: KOMBIINSTR. H06 0135
Revision: 00100000 Serial number: ADT023Y19
Coding: 2F74090502002600010400
Shop #: WSC 02391 823 56573
VCID: 275DE89656AF8826F59-8072
Address 19: CAN Gateway (J533) Labels: 4F0-907-468.clb
Part No SW: 4F0 907 468 K HW: 4F0 907 468 F
Component: GW-BEM 4CAN-M H06 0025
Revision: 4LA80024 Serial number: 2400L091198464
Coding: 000303
VCID: 377D38D6860F18A6659-8062
Subsystem 1 - Part No SW: 8K0 915 181 C HW: 8K0 915 181 C
Component: J367-BDM H07 0107
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 97
Mileage: 151448 km
Time Indication: 0
Date: 2008.08.13
Time: 00:00:41
Freeze Frame:
Bin. Bits: 00000
Voltage: 12.50 V
Count: 11
Bin. Bits: 1000
Time: 0.00 s
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 97
Mileage: 151448 km
Time Indication: 0
Date: 2008.08.13
Time: 00:06:11
Freeze Frame:
Bin. Bits: 00000
Voltage: 12.40 V
Count: 12
Bin. Bits: 1000
Time: 0.00 s
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 97
Mileage: 151448 km
Time Indication: 0
Date: 2008.08.13
Time: 00:15:05
Freeze Frame:
Bin. Bits: 00000
Voltage: 12.40 V
Count: 12
Bin. Bits: 1000
Time: 0.00 s
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 97
Mileage: 151448 km
Time Indication: 0
Date: 2008.08.13
Time: 00:15:05
Freeze Frame:
Bin. Bits: 00000
Voltage: 12.40 V
Count: 12
Bin. Bits: 1000
Time: 0.00 s
02103 - Control Module 2 for Vehicle Electrical System (J520)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 97
Mileage: 151448 km
Time Indication: 0
Date: 2008.08.13
Time: 00:15:09
Freeze Frame:
Bin. Bits: 00000
Voltage: 12.40 V
Count: 12
Bin. Bits: 1000
Time: 0.00 s
Address 42: Door Elect, Driver (J386) Labels: 4F0-959-793.clb
Part No SW: 4F0 959 793 R HW: 8K0 959 793 D
Component: TSG FA H11 0250
Revision: Serial number: 0000100694245
Coding: 011C06204041410001
VCID: 46834512F1E5712EEEF-8013
2 Faults Found:
01320 - Control Module for Climatronic (J255)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 97
Mileage: 151448 km
Time Indication: 0
Date: 2008.08.13
Time: 00:00:09
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 97
Mileage: 151448 km
Time Indication: 0
Date: 2008.08.13
Time: 00:05:56
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 N HW: 4F0 907 289 N
Component: Komfortgeraet H28 0240
Revision: 02400028 Serial number: 01168893990000
Coding: 0131579
VCID: 356132DE5C03EAB6775-8060
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 4F0 910 177
Component: Innenraumueberw.H01 0020
6 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 98
Mileage: 151448 km
Time Indication: 0
Date: 2008.08.13
Time: 07:15:14
02072 - Control Module for Energy Management (J644)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 97
Mileage: 151448 km
Time Indication: 0
Date: 2008.08.13
Time: 00:00:00
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 97
Mileage: 151448 km
Time Indication: 0
Date: 2008.08.13
Time: 00:00:10
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 97
Mileage: 151448 km
Time Indication: 0
Date: 2008.08.13
Time: 00:15:04
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 97
Mileage: 151448 km
Time Indication: 0
Date: 2008.08.13
Time: 00:15:04
01565 - Luggage Compartment Light (W3)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 97
Mileage: 151448 km
Time Indication: 0
Date: 2008.08.13
Time: 00:16:39
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H13 0100
Revision: Serial number: 00000000613953
Coding: 0001104
VCID: DEB30D72097589EE46F-808B
5 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 97
Mileage: 151448 km
Time Indication: 0
Date: 2008.08.13
Time: 00:00:00
Freeze Frame:
Voltage: 12.500 V
Temperature: 77.0癈
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 97
Mileage: 151448 km
Time Indication: 0
Date: 2008.08.13
Time: 00:06:00
Freeze Frame:
Voltage: 12.500 V
Temperature: 77.0癈
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 97
Mileage: 151448 km
Time Indication: 0
Date: 2008.08.13
Time: 00:00:00
Freeze Frame:
Voltage: 12.500 V
Temperature: 77.0癈
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 97
Mileage: 151448 km
Time Indication: 0
Date: 2008.08.13
Time: 00:00:00
Freeze Frame:
Voltage: 12.500 V
Temperature: 20.0癈
01330 - Central Control Module for Central Convenience (J393)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 97
Mileage: 151448 km
Time Indication: 0
Date: 2008.08.13
Time: 00:15:00
Freeze Frame:
Voltage: 12.400 V
Not Recogn.
Address 52: Door Elect, Pass. (J387) Labels: 4F0-959-792.clb
Part No SW: 4F0 959 792 R HW: 8K0 959 792 D
Component: TSG BF H11 0250
Revision: Serial number: 0000100692390
VCID: 4581421ECCE37A36E75-8010
3 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 97
Mileage: 151448 km
Time Indication: 0
Date: 2008.08.13
Time: 00:00:10
02115 - Locking Unit for Central Locking
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 7
Reset counter: 79
Mileage: 150282 km
Time Indication: 0
Date: 2019.02.17
Time: 18:50:29
01336 - Data Bus for Comfort System
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 97
Mileage: 151448 km
Time Indication: 0
Date: 2008.08.13
Time: 00:15:04
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 D HW: 4F0 907 801 B
Component: EPB CEFC0090 H05 0090
Revision: --H05---
Coding: 0000111
Shop #: WSC 02145 785 00200
VCID: 2149F68EF88B7616BBD-8074
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 H
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000003
VCID: 3F8D50F66E3F20E6AD9-806A
Address 56: Radio
Cannot be reached
Address 5F: Information Electr.
Cannot be reached
Address 62: Door, Rear Left (J388) Labels: 4F0-959-795.clb
Part No SW: 4F0 959 795 M HW: 8K0 959 795 B
Component: TSG HL H10 0251
Revision: Serial number: 0000100674412
Coding: 010804204041220001
VCID: 43855C06C2D74406C91-8016
Address 72: Door, Rear Right (J389) Labels: 4F0-959-795.clb
Component: TSG HR H10 0251
Revision: Serial number: 0000100702550
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 97
Mileage: 151448 km
Time Indication: 0
Date: 2008.08.13
Time: 00:05:56
End ---------------------------------------------------------------------
Reply
Apr 8, 2021 | 05:41 AM
I have the exact same problem!!
btw, the satnav not working is probably because the model you have should have DVD which stores the maps, but i wouldn't use the satnav anyway, its slow as heck and probably outdated.
You are better off with waze on your phone in that respect, or installing an aftermarket android unit, but first you need to get the radio unit at the back working, i'm in the same boat as you! let me know if you got somewhere, next step for me is wiretracing!
Reply
Subscribe
