2011 A6 3.0 Burning Oil / Coolant
Old Sep 27, 2011 | 04:42 PM
Ganellon's Avatar
Default 2011 A6 3.0 Burning Oil / Coolant
Hi everyone,
I have a 2011 A6 that I purchased a little over a year ago.
It has less than 15K miles.
Recently, the "low coolant" and "low oil" indicators came on within a few days of each other. When the oil light came on, there was a strong oil odor in the car, but no oil in the engine compartment that I could find.
I brought the car to the dealer to evaluate the condition, and they've told me that there is nothing wrong, and that I should expect to add oil and coolant every so often.
In the 30 years of car ownership, I've never had a car that consumed coolant or oil unless there was a problem, and since it's consuming both, my initial thought was a problematic head gasket. Since the car is relatively young, I'm concerned.
I believe the technician is being honest with me, given the diagnostic tools at their disposal, but I'm also concerned that those diagnostics are simply not reporting the condition, and that I'm going to seriously damage the engine by driving it while the condition persists.
Has anyone else had a similar experience with this particular year / model so that I can believe it's typical, rather than symptomatic?
Thank you for your replies.
-Drew
Old Sep 27, 2011 | 04:51 PM
bigdadi's Avatar
2011 is in manufacturer new car warranty ... Make them repair under warranty and then if they can't fix it after certain number of repair ... ask Audi buys back under LEMON LAW, or Audi will offer you trade-in option also.
I won't keep and drive a car like that, just find the best way to lose least money.
Old Sep 28, 2011 | 06:34 PM
bob martin's Avatar
Make sure you understand and follow the lemon law requirements for your state. Make sure you continue to take it back and make sure you get an inspection order that states your complaint - losing oil and coolant - not something generic. after 5 or 6 times, they probably have to buy the car back. Your fall back plan is to let it run out of oil or coolant and let it blow up the engine. Not as neat, but just as effective.
BTW, it sounds like a head gasket has gone south on you. A compression check is called for.
Good luck,
Bob
elkgrove65
Nov 2, 2012 06:22 PM
yoyoman
Audi Q7
Apr 18, 2012 08:14 AM
Ganellon
Sep 27, 2011 04:30 PM
BMF!
Jan 6, 2009 06:52 AM
Sebass
Apr 7, 2006 05:14 AM
