2014 Audi A6 2.0L Orange Engine Dash Light
Problem -
Getting Orange engine lamp ON dash. Both radiator fans run seemingly at full speed when engine is running.
Solution -
Reset code using VCDS (both radiator fans stop), Orange engine lamp on dash turns OFF
Problem -
Re-occurs a day or two later
Solution ?
Thursday,30,May,2024,18:32:43:04221
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 24.5.0.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20240429 DS355.0
www.Ross-Tech.com
VIN: WAUFFAFC7EN152848 License Plate:
Mileage: 112002km-69594mi Repair Order:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 3B 42 44 46 52 53 55 5F 62
72 8F 90
VIN: WAUFFAFC7EN152848 Mileage: 112002km-69594miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3B-Sensor Elect. -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
8F-Pretens. Frt Left -- Status: OK 0000
90-Pretens. Frt Right -- Status: OK 0000
Address 01: Engine (R0MA-CAED) Labels:. 06H-907-115-CAB.clb
Part No SW: 4G0 907 115 P HW: 8K2 907 115 L
Component: 2.0l R4/4V TF H09 0005
Revision: ECH09--- CVN: B48AB3B3
Coding: 4A2A0013242600062000
Shop #: WSC 63930 001 1048576
ASAM Dataset: EV_ECM20TFS0114G0907115P 001006
ROD: EV_ECM20TFS011_AU57.rod
VCID: 323D1B4D94AE664A917-8066
VINID: 9D19565915931D578114220420A41D5779
1 Fault Found:
8113 - Performance Malfunction in Cooling System
P2181 00 [11101101] - -
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 111971 km
Date: 2024.05.25
Time: 18:41:31
Engine RPM: 1570.00 /min
Normed load value: 36.9 %
Vehicle speed: 2 km/h
Coolant temperature: 77 °C
Intake air temperature: 43 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 13.758 V
Unlearning counter according OBD: 40
Engine status: COENG_RUNNING
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 4G0 927 158 AD HW: 0BK 927 156 AL
Component: 0BK 20TFSIUSA H18 1004
Revision: --H18--- CVN: E2B0670E
Coding: 000002
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMAL551211 002022
ROD: EV_TCMAL551211_002_AU48.rod
VCID: 70B9D1455A22145AA73-8024
No fault code found.
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 L HW: 4G0 907 379 L
Component: ESP PREMIUM H09 0450
Revision: -------- Serial number: --------------
Coding: 21A7170184E5E8805B00
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremiAU57X 004039
ROD: EV_ESPPremiAU57X_004_AU57.rod
VCID: 3A2D336D4CDE9E0A597-806E
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 EC HW: 4H0 907 064 EC
Component: BCM2 2.0 H36 0521
Revision: 00002001
Coding: 09883046000000000000
VCID: 6E85CF3D409602AAB5F-803A
Subsystem 2 - Part No SW: 4H0 905 852 C HW: 4H0 905 852 C
Component: J764 ELV MLB H40 0046
Serial number: 0214000068344015
Address 08: Auto HVAC (J255) Labels:* None
Part No SW: 4G0 820 043 BG HW: 4G0 820 043 BG
Component: KLIMA 2 ZONEN H14 0096
Serial number: 30061700110005
Coding: 64012018C9
Shop #: WSC 08410 004 1048576
ASAM Dataset: EV_AirCondiBasisUDS 004002
ROD: EV_AirCondiBasisUDS_004.rod
VCID: 6597B01195E0C1F2C45-8030
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 CG HW: 4H0 907 063
Component: BCM1 2.0 H12 0130
Revision: 11012002 Serial number: 00000001731009
Coding: 06002091063C9FE08100088380003908CF9CD208A209022100 0004406000
VCID: 6FBBD239479C0BA2BE9-803A
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
Component: WWS57X 140409 H37 0080
Serial number: 140412111130
Coding: 0045F7
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 22503011
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 D HW: 4G0 941 531 D
Component: E1 - LDS H07 0044
Serial number: 03 04 2014 00001880
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Serial number: 0000002274555RB4AN03
Subsystem 5 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H03 0002
Serial number: 0609CF17000000000001
Address 15: Airbags (J234) Labels:* 4H0-959-655.clb
Part No SW: 4G0 959 655 A HW: 4G0 959 655 A
Component: Airbag10.43 H33 0033
Revision: -------- Serial number: 003D8004125- Dataset Number: 4G0909602E 0007
Coding: 303234373130303030314A55304C34473053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_VW51.rod
VCID: 33331E496BB46F429A1-8066
Seat occupied recognition:
Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Component: BF-Gewichtss. H11 0046
Serial number: 6940000Y1400013NG80N
Crash sensor for side airbag: driver side:
Serial number: 3575HRB40512FNOG51NM
Front Passenger's Side Airbag Crash Sensor:
Serial number: 3585HRB40652BJ1KD11U
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 3515JRB400I5109QAGNB
Passenger side rear thorax airbag crash sensor:
Serial number: 3525JRB400G5109QBPSP
Crash sensor for front airbag: driver side:
Serial number: 3554VRB400O50U86MPE9
Crash sensor for front airbag: front passenger side:
Serial number: 3564VRB400Q50U86AHBW
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
Component: Lenks.Modul H05 0201
Revision: 00000000 Serial number: 20140415000115
Coding: 000014
VCID: 303911459A22545AE73-8064
Subsystem 1 - Part No SW: 4G0 951 528 D HW: 4G0 951 528 D
Component: E221 - MFL H09 0010
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 950 T HW: 4G8 920 950 T
Component: MBenUsa H43 0411
Revision: 27450259 Serial number: 658220314592011
Coding: 0BE609040B41D705020000
ASAM Dataset: EV_RBC7KMID 004048
ROD: EV_RBC7KMID.rod
VCID: 40D941852A02C4DA173-8014
Address 19: CAN Gateway (J533) Labels:| 4H0-907-468.clb
Part No SW: 4G0 907 468 AD HW: 4G0 907 468 AC
Component: J533--Gateway H13 0050
Revision: -------- Serial number: 00000001350422 Dataset Number: 4G0909515H 0067
Coding: 00C1032900
GVL: FD81C808DC60600D0000
ASAM Dataset: EV_GatewPkoUDS 001019
ROD: EV_GatewPkoUDS_001_AU57.rod
VCID: 72BDDB4D542E264A517-8026
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
Serial number: 0179663003
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4G8 959 760 HW: 4G8 959 760
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000097860999
Coding: 0058130000002001000001010101102030303232203232
VCID: 77ABEA593FCC4362669-8022
Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
Component: SARA 6D H03 0056
Revision: -------- Serial number: EJ1BPA8206YLZE Dataset Number: 4G0909573C 0006
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 3635275D78C67A6ABDF-8062
Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0507
Coding: 011F17004E00628002000002
VCID: 47CB5A990FACF3E2D69-8012
Address 44: Steering Assist (J500) Labels:| 4G0-909-144.clb
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H40 0010
Revision: 00001000 Serial number: 0010479320 Dataset Number: 4G0909852K 0030
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0332851685
Coding: 0106023A00FA400480B0080002050E00000000000000000000 0000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0081
Serial number: 00000000000000215972
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 4G8 959 591 HW: 7P0 959 591 C
Component: J245 PS40.039 H01 0008
Serial number: WOO28804938
Coding: 101F00
2 Faults Found:
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 243
Mileage: 109792 km
Time Indication: 0
Date: 2024.02.14
Time: 12:59:49
02616 - Fuel Tank Cap; Unlock
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 243
Mileage: 109792 km
Time Indication: 0
Date: 2024.02.14
Time: 13:00:09
Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb
Part No SW: 4G8 959 792 J HW: 4G8 959 792 G
Component: TSG BF H03 0507
VCID: 46D5579D08A6EAEA2DF-8012
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 H HW: 4H0 907 801 A
Component: EPB-4 H03 0015
Revision: -------- Serial number: 00000001035700 Dataset Number: 4G0909522D 0007
ASAM Dataset: EV_ParkiBrake 001028
ROD: EV_ParkiBrake_VW51.rod
VCID: 2D0708318D9039B2CC5-8078
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Component: ....LWR12.... H02 0010
Serial number: 140411-0002-260
Coding: 1221A6101002A400
ASAM Dataset: EV_HeadlRegulBasic 005001
ROD: EV_HeadlRegulBasic_AU21.rod
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 4G0 035 190 D HW: 4G0 035 190 B
Component: RMC Cnct SirX H55 0801
Coding: 0100000001C0D94F402B040302010000000000
Shop #: WSC 63888 001 1048576
VCID: 211FE401C1C8EDD278D-8074
Subsystem 1 - Part No SW: 4G0 919 603 B HW: 4G0 919 603 B
Component: DU6 Basic H43 0084
Serial number: 9464D%0E2657771
Subsystem 2 - Part No SW: 4G1 919 610 B HW: 4G1 919 610 B
Component: E380 BDT C7 H11 0204
Serial number: 90349ND80010C
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4G8 959 795 J HW: 4G8 959 795 G
Component: TSG HL H03 0507
Coding: 010F17004000628002000002
VCID: 49CF5CA119B80592C0D-801C
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H03 0507
Address 8F: Pretens. Frt Left (J854) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 945 B HW: 4H0 980 945 C
Component: RGS-VL H13 0080
Dataset Number: 4G0909614C 0001
Coding: 00060000031F030000030801424CDA010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 313F144191A85D52E8D-8064
Address 90: Pretens. Frt Right (J855) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 946 B HW: 4H0 980 946 C
Component: RGS-VR H13 0080
Dataset Number: 4G0909615C 0001
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
End----------(Elapsed Time: 01:49, VBatt start/end: 13.1V/13.7V)-----------
2) Transmission Measurements -
Thursday,30,May,2024,19:12:35:04221
www.Ross-Tech.com
Address 02: Auto Trans (4G0 927 158 AD)
19:12:06
IDE00024 ATF temperature 65 °C
IDE00025 Coolant temperature 89 °C
3) HVAC Measurements -
Thursday,30,May,2024,19:06:34:04221
www.Ross-Tech.com
Address 08: Auto HVAC (4G0 820 043 BG)
19:06:06
IDE00025 Coolant temperature 94.50 °C
IDE00102 Control Module temperature 56 °C
IDE00380 Coolant fan 1: activation 32 %
IDE00381 Coolant fan 2: activation 126 %
IDE00971 Coolant fan activation: specified value 58.4 %
IDE01236 Coolant recirculation pump not activated
IDE01266 Coolant shut-off valve closed
What I have noticed :
The "Auto Scan" readout above was done about 1 minute after an engine cold startup. Not sure the "Coolant temperature: 77 °C" is supposed to be this high (1 minute after startup).
The gas cap retainer chord has been broken for years. VCDS registers this as a fault, not a problem for me.
Orange Engine dash light came ON for the first time 5 days ago. The same fault code has since been reset 3 times, after each drive. The car seems to drive OK with the Engine light ON, however the radiator 2 fans are running at max.
Bought this car new in 2014. Not sure is this is related, but for the past 2 years or so, every cold start (we're in Miami where morning "cold" start temp is generally 76 - 82 degrees F) takes the tachometer about 45 seconds to settle from say 1.2K RPM, to engine idle, say 500 RPM. Once the idle settles, the transmission is engaged & car is driven.
With NO fault codes, while driving for 20 minutes with outside temp at approx 32 C degrees, with the AC OFF neither fan seems to be running. After coming to a stop (verified neither fan is ruuning), engaging AC at lowest temp setting, cabin fan ON full, cold air through cabin vents, both radiator fans engage at very high speed. Then, when turning AC off, both radiator fans stop.
While driving quite aggressively, I monitored the coolant temp. The highest reading was 98 C. The AC ON / OFF did not seem to change the coolant range by more than a couple degrees. After idling several minutes (radiator fans not spinning), the VCDS coolant temp of 94.5 C dropped to about 87 C.
Each time the fault code was triggered when the VCDS coolant temp measured 74, 77, 78 degrees C. One time the engine light came on within a minute of engine cold start, the other 2 times not sure as my wife was driving...
An engine start with the existing Engine fault dash lamp ON, both fans spin at max (with or without AC).
Thank you for taking a look. Any ideas would be greatlty appreciated.
Solution -
Problem -
Solution ?
Code:
1) Auto Scan
www.Ross-Tech.com
72 8F 90
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 111971 km
Date: 2024.05.25
Time: 18:41:31
Coding: 000002
Revision: 00002001
Coding: 64012018C9
Coding: 0045F7
Coding: 02006D
Coding: 000014
Coding: 00C1032900
ROD: EV_SARA2.rod
Coding: 101F00
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 243
Mileage: 109792 km
Time Indication: 0
Date: 2024.02.14
Time: 12:59:49
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 243
Mileage: 109792 km
Time Indication: 0
Date: 2024.02.14
Time: 13:00:09
ROD: EV_RGS_L.rod
ROD: EV_RGS_R.rod
www.Ross-Tech.com
19:12:06
www.Ross-Tech.com
19:06:06
