95 A6 engine speed sensor ohm reading
Old Jul 24, 2010 | 09:43 AM
95 Audi A6's Avatar
Default 95 A6 engine speed sensor ohm reading
I have a 95 A6 that won't start. I have a engine speed sensor that has 1050 ohm's of resistance. The spec that i've found say's the reading should be between 400-1000. Because the reading is a little over should I assume the sensor is bad and replace it? Do these go be often? Thanks for the help.
Old Jul 24, 2010 | 12:41 PM
jackson101's Avatar
no, 1050 is not that far off and could be caused by a temperature differential ( warmer wires, higher resistance ) or an inaccurate meter. You need to dig deeper. It's not essential to have the VAG com software for this, but sure does help. What OBD codes are reported?
Old Jul 24, 2010 | 02:46 PM
95 Audi A6's Avatar
I didn't think that was far enough off, I'm waiting on the 2x2 connector to come in and check the codes.
vtraudt
Nov 15, 2010 11:45 AM
twoaudis
Aug 9, 2010 02:15 PM
bshouler
May 15, 2009 08:46 AM
bshouler
Apr 17, 2009 08:44 AM
byouells
Jan 1, 2007 08:11 PM
