'95 A6 starting problem
Old May 20, 2009 | 09:39 AM
Lindz's Avatar
Originally Posted by Midniteoyl
OK.. the IN2 is the reminder to bleed your brake fluid. The clicking of the Purge regular is normal. The cranking, starting after awhile, then shutting down after 20 mins is could be a temp sensor, most likely the Coolant Temp sensor. I had one fail LOW once and the car was hard to start, would catch, then die after 10-15mins and wouldnt restart again for at least an hour, usually 2. It seems that when they fail LOW, the ECU thinks its -40F and when the engine starts to warm, it goes rich and dies. Nobody, even a dealer, could figure it out. Its worth a shot to check it out. Air Temp sensors and the MAF would be other places to look, as would the CAM and Crank sensors.
Yeah you might be right i had to change the MAF on my B5 when i added a K&N air filter. i guess i am going to start checking pricing on that and i guess the brown looking one that is towards the back.
Old May 20, 2009 | 01:24 PM
Midniteoyl's Avatar
Wow... my grammer isnt very good at 2 am
Did you put a K&N on this car too? I hate those things.. always screwing up MAF's.
Old May 20, 2009 | 05:43 PM
Lindz's Avatar
Nope i didn't put the K&N filter on the A6 didn't think they even had one for that model.
Lourenstien
Oct 30, 2012 07:49 PM
bradwall96
Apr 25, 2011 05:10 PM
PaulA4
Feb 20, 2007 06:55 PM
lhayes
Jun 30, 2006 09:20 AM
PaulA4
Mar 9, 2006 04:30 PM
