96-A6 p1602 code
Old Oct 14, 2008 | 10:58 PM
geno131's Avatar
Default 96-A6 p1602 code
I can not get thru emissions in CT. I clear this code and it returns on startup. I have disconnected batt pos cable, checked ECU connections under pass side front carpet. I have searched this forum thoughroughly for correcting/eliminating this code permanently. Thanks in advance for any assistancce with this nightmare. geno
Old Oct 15, 2008 | 06:06 PM
oc_audica's Avatar
Clear the cel, leave the bat disconnected over night... then see if that helps?
have you checked the charge on the battery?
Old Oct 15, 2008 | 08:45 PM
geno131's Avatar
OC, thank you for the response. My son and I are going to disconnect batt now(8:40p EST) for the night. FYI-p1602 codes only appear when motor running, CEL is NOT on-does this make sense?
Old Oct 15, 2008 | 08:56 PM
a6hcw's Avatar
For a 1996 A6 Audi with the 2.8L AFC engine, P1602 is power supply (B+) terminal 30 low voltage, per Bentley. To test, connect the V.A.G. 1527 voltage test lamp to the ECM socket B10 (continuous B+) and to engine ground.
You may need the BentleyPublishers.com Audi shop manual CD, since it has the wiring diagrams. You may get the CD from www.themotorbookstore.com or www.themotorbookguy.com .
Old Oct 16, 2008 | 11:54 PM
geno131's Avatar
OC,
OK, it's 11:50p EST, we reconnected both pos and neg terms to batt. With key at on position for 10 min's, we waited then off-then started Audi. P1602 was still on Actron scanner. Shut off, restarted and p1602 still there. I do appreciate your response and suggestion.
geno
Old Oct 17, 2008 | 12:04 AM
geno131's Avatar
a6hcw,
Thank you. My mechanic friend, I believe has VAG sys and presumably VAG 1527 test lamp, I will ask he test ECM socket B 10. Is the "ECM" the module/metal box my son and I found under the pass front carpet/plastic shield?? Thank you.
Old Oct 17, 2008 | 12:22 AM
geno131's Avatar
OC,
One other follow-up to your post, the batt is a VW/Audi type appears new, but I will check standing voltage, running voltage and volt off alternator in AM. My dash volt gauge has always shown better than 12 and under 16 for past 2 years. Thanks again.
A6 Quattro V6 30V
Aug 6, 2010 02:06 AM
rabenson
Mar 17, 2008 11:38 PM
rabenson
Mar 14, 2008 12:22 AM
pathak76
Dec 12, 2007 03:35 PM
MilitantGrunt
Nov 1, 2006 09:16 AM
