96 Audi A6 {base} - Replacing Front Sway bar/anti-roll bar bushings
Old Jul 5, 2013 | 01:38 AM
moendev's Avatar
Unhappy 96 Audi A6 {base} - Replacing Front Sway bar/anti-roll bar bushings
I have 96 A6 base edition and I am trying to replace the front sway bar bushings, as they are deteriorated. The problem I am having is getting the second nut off, it just keep spinning(I had to place another 3/4 socket thru a hole on top of the subframe) while using another socket to remove the nut. However with the second one, there isn't enough clearance to get socket in the hole let alone the ratchet. I was thinking maybe an offset box set wrench might fit and hold the second bolt(but it might not be deep enough) without lifting the engine to remove the subframe to get to that second hole. So... The question is - Any Ideas on how I can accomplish this without having to lift the engine?
96 Audi A6 2.8 Base 175,000 miles
Old Jul 20, 2013 | 10:03 PM
moendev's Avatar
Default Sway bar bushings
If I can get the second nut off the mount bracket would I be able to get it back on after replacing the bushing without having to move the engine to lower the sub-frame... please help I don't wanna take it off and not be able to get back on!!!
muscletat
Jun 23, 2013 07:49 AM
BaseDrifter
Jul 17, 2012 09:11 AM
ravestar
Nov 12, 2007 03:07 PM
granite statah
Sep 15, 2007 08:55 PM
harryc
Sep 24, 2006 07:29 PM
