Anti roll bar Bushes?
Old Sep 23, 2006 | 08:04 PM
harryc's Avatar
Default Anti roll bar Bushes?
I am about to fit above to A4 120k miles.
Anyone know if bumping sound from front suspension is due to wear on these?
I have checked all the arms and shocks were replaced at 90,000 miles
Old Sep 24, 2006 | 06:30 AM
AWDaholic's Avatar
Senior Administrator
Default RE: Anti roll bar Bushes?
OK, HarryC, first, let me correkt your spelink... You're referring to b - u - s - h - I - N - G - S, not bushes. Bushes are busy-looking squat not-quite-tree-like objekts. Bushings are the rubber, polyethelyne or polystyrene or some other poly-synthetic material, or even metal (in extreme cases) objects that dampen connections between suspension parts and the frame, generally speaking.
To answer your question, yes, that could be the culprit. Is the bump noins rythmic, or does it occur primairly when you hit uneven road surfaces, such as (no pun intended) bumps?
Old Sep 24, 2006 | 08:50 AM
harryc's Avatar
Seems to be a thing in the UK to call them bushes as they are being advertised on this search engine as same!
anyway the noise is only on certain bumps and I had to replace bushes/bushings on my wifes Golf of 3years age due to a fault on these cars.
Old Sep 24, 2006 | 10:25 AM
techbod's Avatar
bushes = UK
bushings = USA
but if you type bushings in your search you get more results
tie rods seem to be a common fail due to speed bumps in the UK ( in the USA ) they call the track rod ends tie rod ends
[IMG]local://upfiles/12092/E33790224E614F2D80A541F6A05E6C05.jpg[/IMG]
Old Sep 24, 2006 | 07:29 PM
AWDaholic's Avatar
One of these days we'll hafta get together and do a thread just for translating terms, for the blokes (means... ummm... "Guys," I'm pretty sure)
p.s. Harryc, sorry, I dint realize you were from blighty. In my Americentric arrogance I naturally assumed you were American, like me & Avant80
muscletat
Jun 23, 2013 07:49 AM
ianc
Aug 20, 2009 03:47 AM
gaberossi
May 30, 2009 04:12 PM
kchao2000
Oct 20, 2006 08:27 PM
Skuy4
Jul 25, 2004 07:44 PM
