97 A6 ATF
Old Jul 12, 2008 | 05:07 PM
NH_USA's Avatar
Default 97 A6 ATF
I have to change the radiator in my 97 A6 2.8Q and will loose a bit of transmission fluid.
Bently says that the O1F transmission 7/95> requires VWATF G052162and >6/95 uses Dextron.
Does this mean that vehicles manufactured in July of 95 and after uses the VW ATF?
Old Jul 14, 2008 | 10:34 PM
NH_USA's Avatar
Default RE: 97 A6 ATF
Bump
Old Jul 16, 2008 | 10:08 PM
NH_USA's Avatar
Please help I need to get the ATF before beginning the job.
Old Jul 20, 2008 | 12:00 AM
NH_USA's Avatar
Bump
Old Jul 20, 2008 | 01:30 AM
gmatov's Avatar
Can't help, but mebbe a bump.
I haven't been able to post. So trying this.
I think that what you have indicated may be true.
Brake fluid, and PS, do NOT deviate from recommendation.
Cheers,
George
Old Jul 21, 2008 | 12:29 AM
a6hcw's Avatar
7/95> = 7/95 and after.
You can getan ATF refill kit from www.blauparts.com, which includes an ATFhand pump and instructions. You will need VAG-COM to get the transmission temperature, so that you get the correct ATF fluid level per the Bentley instructions. You can get the VAG-COM from www.ross-tech.com.
For a 1997 A6 the ATF should be changed every 45,000 miles.
The vehicle must be level and securely on jack stands on a solid reinforced concrete surface. You may need to order extra ATF when you get the refill kit, since you lost some when you did the radiator, etc.
