97 a6 heating problems
Old Sep 17, 2007 | 05:29 AM
e_kade's Avatar
Default 97 a6 heating problems
my a6 temp light was flashin but temp gauge wasat halfway not movin up. so i procedded home, turned the car off and it proceeded to spill coolant everywhere. no radiator fan turned on.. so today i had read in the forum if the AC is on and both fans run, its not a fan, probably a fuse, relay , switch. ok well both fans RUN when teh AC is on.
welli tested the switch jumped the connectors and both fans ran in the forum they said if they both work, then its a switch. . so i drove it to napa replaced my switch. drove for about 15 mins, coolant light started flashing, gauge didn'tmove though. so i got home turned off the car,.. coolant had sprayed out of something, and it was so pressurized it wanted to blow up ya know.. im not sure where to go from here if you could help it would be greatly apprcieated!
Old Sep 17, 2007 | 07:19 AM
techbod's Avatar
Default RE: 97 a6 heating problems
coolant temp sensor/ stuck thermostat/ fuses and relays
Old Sep 18, 2007 | 06:45 PM
e_kade's Avatar
my guess is the thermo, can i access it easily or do i have to take stuff apart
Old Sep 19, 2007 | 03:30 PM
pluto126's Avatar
I just had a similar problem on my 1996 A6 where the light kept flashing and when I opened the hood you could see coolant spilling out. Turns out there was a crack in the coolant holder tank. they are replacing the tank and hopefully it fixes the problem.
Old Sep 19, 2007 | 06:31 PM
e_kade's Avatar
yeah let me know........ my coolant was spillin out of the bottom where the sensor is. but it was becauseof all the pressure. i think i need a new o ring. did you overheat at all?
Old Sep 20, 2007 | 08:46 AM
pluto126's Avatar
I just got my car back and so far so good. Looks like it fixed the problem.
When the light first started flashing the tempature gauge stayed where it always is but when I popped the hood there was smoke coming out from the hose that lead to the coolant tank. Hope this helps. It was inexpensive to fix only $131 where I took it to.
Old Sep 20, 2007 | 09:03 AM
e_kade's Avatar
our problems were similar but a little different . I just rolled 106k on the car. And this is the first problem. i just replaced the struts, and now i just bought a Complete Timing kit rebuild kit for only 169.99. !!! comes with everything.. i figure its gonna go out soon, why not be preventive ya know. but thats alot. i will let ya know if it works..
kade
glad to hear your car came out good, and at a good price!
karlo12
May 8, 2015 04:28 AM
ni88les
Oct 21, 2010 06:01 PM
dezhammer16
Nov 20, 2008 04:50 PM
Ge22y
Nov 18, 2008 01:08 PM
procrasturbate
Dec 14, 2007 12:59 PM
