97 Quattro wagon No Spark
Old Apr 23, 2012 | 04:39 PM
andrewsjr4's Avatar
Default 97 Quattro wagon No Spark
My A6 was running rough at low RPMs, all of a sudden one afternoon. Decided to try to get it home. It died at a stop sign on the way. Wont start, no spark in any cylinders. Just hoping for a point in the right direction.. MAF, ECU... I haven't started messing with it too much, just figured out it wasn't getting spark.
Anything helps
Thanks,
Jeff
Old Apr 23, 2012 | 05:31 PM
M5S5's Avatar
Tech Certified
I would check to see if your are getting injector pulse signal from the ecm. If no injector pulse you could have a bad crank sensor.
Upon rereading your post did you actually check for spark or are you guessing?
Check to see if you are getting fuel?
Old Apr 23, 2012 | 08:03 PM
Crisp's Avatar
This is what I thought when my car died in my garage when I was warming it up one morning. Fuel pump it was.
Old Apr 23, 2012 | 09:20 PM
andrewsjr4's Avatar
I originally thought fuel pump. Then i checked a spark plug off each coil pack and got nothing at all. It smelled like I was getting fuel but I can't be sure yet. My buddy suggested crank sensor. How do I check the injector pulse signal?
Old Apr 25, 2012 | 08:48 AM
M5S5's Avatar
Tech Certified
Noid light.Noid Light
ypcyrl
Dec 13, 2013 09:50 PM
haawill
Feb 8, 2009 01:04 AM
Dogcliff
May 26, 2006 11:57 PM
Dogcliff
May 24, 2006 07:02 PM
