99 a6 brakes help please
Old Nov 25, 2006 | 07:25 PM
bc420ak's Avatar
Default 99 a6 brakes help please
hey guys, new here, but i have a minor problem. just did my front brake pads and that all went fine. then i got to the back pads and everything was going fine. until i tried to compress the piston thing in the caliper. it wont move, is there some kind of trick to make it compress? my car is currently on stands in the driveway, and i really need to get to work on monday so if anyone could help asap please?
also, i was looking at http://www.lltek.com/exhaust_tips_a64b_prefaclft.htm and i was just wondering, does this involve anymodification to my bumper? and my cupholders in the back, you know the ones that slide out in the middle of the seat? well neither of them slide out any more, any suggestions?
well i think thats about it for my list of problems currently. if anyone could please help with the brake problem, that would be awesome becasue i really dont want to have to hitch hike to work with my audi in the driveway on stands.......
Old Nov 25, 2006 | 07:32 PM
matt_o121's Avatar
Default RE: 99 a6 brakes help please
not done them myself but many rear calipers have a screw type piston which needs to be wound back when you replace the pads - its to do with the handbrake, so it doesnt need adjustment as the pads wear,
tools can be bought from a local motor factor cheaply.
Old Nov 25, 2006 | 07:35 PM
matt_o121's Avatar
the rear bumper needs cutting to fit the tail pipe trims along with the exhaust heat sheilds, the end of the exhaust pipe will need to be cut before fitting the pipes.
the rear cup holders are weak, if you remove the outer trim by pulling it you should be able to see the retaining clips - or look on audi world for photos in the tech area, you may be able to file the moving parts to them to get them to work or buy new..
Old Nov 25, 2006 | 07:39 PM
matt_o121's Avatar
try this link for an idea of the brake tool : http://www.amazon.com/Lisle-25000-Re.../dp/B0002SQUJU
the tool pushes against one side of the caliper whilst screwing the piston back using 2 pins which fit the cuts on the piston face
Old Nov 25, 2006 | 07:45 PM
bc420ak's Avatar
ya, i kinda figured the tail pipes would involve a bunch of cutting and stuff......
same with the cupholders.......they definitely work good, but not very good design, i got one of em out and realized theres nothing broken at all, just some lazy ******* in my back seat decided to spill something in it and not tell me and just close it, and it got all gooped up so i just had to clean it.
but still with the brakes......so your saying maybe i just have to pretty much screw them back in? i noticed the piston turned both ways without any resistance either way, so i was thinking that wasnt it, but ill go back and try it.....i dont understand why they couldnt just make it push back in like every other car ive seen.....but that sounds like a good possibility, thanks a lot.
if anyone else has any other possiblities it would be greatly appreciated.
Old Nov 25, 2006 | 07:49 PM
bc420ak's Avatar
thanks a lot for that matt, didnt see that link until after i posted.......but that looks like it might help a lot,
i just wish i could rent that or something..........im not gonna need it for a while after i finish this and i dont have a shop, so buying a 55 dollar tool for one use is kinda depressing hahahaha
Old Nov 25, 2006 | 07:53 PM
matt_o121's Avatar
just checked my tool - clockwise to wind them back in
Old Nov 25, 2006 | 07:55 PM
matt_o121's Avatar
you could try this one! http://www.sjdiscounttools.com/lis28600.html
not sure how it works it looks crude, but should do the job, they are worth having most rear calipers are like this
Old Nov 25, 2006 | 08:02 PM
bc420ak's Avatar
hahahaha ya i guess its a little more crude......9 bucks compared to 55? hahaha, thanks a lot though, youve been a big help, im kinda new to this whole scene, just bought my car in june and its the first quality car ive ever owned so its kinda a whole new world tryin to work on this thing. gotta love havin to buy new tools every time you want to fix something
mharris23
Jun 19, 2009 08:59 AM
DomsA4
Apr 24, 2008 06:53 PM
milla290
Jul 19, 2007 01:31 AM
dtownhotcorner
Sep 22, 2006 11:49 PM
dscott
Jul 4, 2006 06:14 AM
