I'd check your fluid first just to make sure and then you can look at the pads to determine which set it is ... pads are only 50 bucks or so a pair I'd just replace all 4 wheels
It means that you should inspect your front brake pads. They may be worn out or the wear sensor wires may be damaged. The rear pads do not have any sensors, so you should also check them for wear.
