99 A6 studdering
Old Dec 31, 2004 | 11:53 AM
redsox's Avatar
Default 99 A6 studdering
I have had my 99 A6 for almost 2 years now. Just recently the Check Engine Light was on so I brought it in for that and some recalls. The dealership replaced the Throttle Valve (recall) and said that probably caused the Check Engine Light issue. They were wrong so I brought it back and they replaced the Air Mass Flow Sensor and Throttle Valve (the first replacement was defective) and said that should do it. Shortly after that the Check Engine Light came back on and the car started running very rough at certain speeds (55-65mph for example). So I brought it back in and had a bunch of needed service performed: Two new rear tires, alignment, timing belt, water pump, oil change. They determined that the Check Engine Light came on because the Air Mass Flow Sensor they installed was defective (2nd defective component installed in two trips from a dealership). I got it back the other day and the car still isn't running as well as when I brought it in. It is not a smooth ride, there is some studdering or rough ride between 55-65mph, and the idle doesn't always seem right. I plan on calling the dealership, but I was curious if there was any help out there first. There is also an issue when I first start the car after leaving work. It seems to stick before changing gear once I leave my parking spot. Someone suggested using 89 Octane, I currently use 91 Octane, but I don't notice this in just the cold weather. Thanks for any help that might be out there.
Old Dec 31, 2004 | 12:17 PM
Jestnomen's Avatar
6th Gear
Default RE: 99 A6 studdering
My car used to shudder at high speeds also, it was caused by a faulty O2 sensor.
matoida6twin
Sep 9, 2008 11:21 PM
laserredgt
Aug 17, 2008 12:49 PM
lavadrifter
Dec 31, 2007 10:32 PM
225tt
Nov 24, 2007 03:00 AM
audi in the yay
Jul 7, 2007 07:13 AM
