A6 2.8 Quattro Transmission in Limp Mode
Old Jan 7, 2013 | 12:06 AM
OscarA6C5quattro's Avatar
Default A6 2.8 Quattro Transmission in Limp Mode
Hi does anyone know how to reset the transmission? I have done a fluid and filter service and gears don't change past 2nd gear. Reverse and 1-2 is good.
Really appreciate your assistance.
Old Jan 7, 2013 | 11:31 AM
TwinTurboC5's Avatar
If you have the Ross-Tech/VCDS software you can check and clear any trouble codes that may be stored in the TCM. If your car is in limp mode there is an obvious problem that needs to be addressed. If you don't have access to any diagnostic equipment, a trip to the dealer or some other Audi service center will probably be required to have the issue addressed or diagnosed.
Old Jan 8, 2013 | 09:45 AM
Thank you for your reply. My transmission started to slip because it had old fluid in it which I have since changed for a fully synthetic Castrol ATF blend. The old oil was black and there was a fair bit of sludge in the bottom of the pan and magnets. I will try and download software from the source you suggested and hope for the best. I will let you know what the outcome is.
venechamito
Aug 18, 2013 09:28 AM
madgunz
Apr 21, 2011 12:36 PM
jpcallmotor
Jul 9, 2010 01:41 PM
badge424
Dec 20, 2007 03:13 PM
jeromehawaiii
Aug 1, 2007 08:41 PM
