a6 2.8 v6 C4 how to bleed cooling system?
Old Jan 28, 2014 | 02:29 AM
lionel a6 2.8 v6 c4's Avatar
Default a6 2.8 v6 C4 how to bleed cooling system?
car gets very hot within few minutes.
the waterpipe burst and the headgascket blew. i replaced both including oil,oilfilter and cylinder headbolts.
car still gets very hot very fast. when i drive it, it struggles to gain revs and then it just cuts out. there is also allot of noise coming from the hydraulic lifters. also want to know what oil is recommended for this car.
how do i bleed the cooling system?
please help.
Old Jan 28, 2014 | 08:45 AM
Nebuchadnezzar's Avatar
Most Audi models are recommended to run 0w40, full synthetic.
As for bleeding the coolant system, there should be a 6mm (?) allen head bolt found right around your intake manifold that needs to be cracked open and bled until a steady stream comes out. Once that happens, tighten the bolt. Also, you may have to bleed the system at the heater core.
One of the hoses has a circle with a small pin hole in the middle. Loosen the retaining clip by simply sliding it down, then slowly pull the hose off of the metal outlet pipe until the circle / hole clears the end of the pipe. You should see some air escape along with some coolant. Again, once a steady stream comes out, replace the hose to its original position and put the clip back where it was.
Old Feb 10, 2014 | 05:07 AM
Default want to change hydraulic lifters
please give me a guide on how to change the hydraulic lifters step by step. i have allready taken out the cranks etc and i know how to place everything back and do the timing. just never did the lifters. want to know how to know what is inlet and exhaust and wich lifters go where and any special tricks etc.
please help
kbunting
Apr 13, 2015 10:08 PM
madridlover
Dec 4, 2011 12:15 PM
MauriSSio
Jan 9, 2008 08:51 AM
carhopper
Jul 22, 2007 12:54 PM
lacrosse22
Feb 10, 2006 09:34 PM
