How to bleed cooling system please help
Old Jul 21, 2007 | 03:25 PM
carhopper's Avatar
Default How to bleed cooling system please help
I have searched everywhere for this. Anyone know how to do it. I'm running hot if I idle for 10 minutesandit starts to climb up a tick. Level is good, tstat recently replaced when I had the timing belt done. Any ideas?
Old Jul 21, 2007 | 03:31 PM
Cheese Eater's Avatar
Default RE: How to bleed cooling system please help
might be the thermostat you just had replaced. i've had a few i replaced on past cars that were stuck shut.
Old Jul 21, 2007 | 05:16 PM
carhopper's Avatar
If so, the dealer should replace that for free. The extra heat from 1 tick cracked my reservoir tank and now it leaks. I'm waiting for that to get in before I go to the dealer. I don't want them to have an excuse. How about the bleeding procedure. Isn't it required?
Old Jul 21, 2007 | 09:54 PM
2k S4's Avatar
Drivers side, next to the throttle body. Down there is a hax nut, that is the bleader.
Old Jul 22, 2007 | 09:08 AM
i guess i don't see a reason you need to bleed it. is it due for a change or is the color a rusty brown and you can see rust particles in the mix? coolant doesn't just go bad, but if you want to make sure you have a good water/antifreeze mix, get a coolant meter from a parts store for 6 bucks and check. no sense in wasting even more money on more antifreeze if the coolant isn't the problem.
Old Jul 22, 2007 | 12:54 PM
2k S4's Avatar
ORIGINAL: Cheese Eater
If he just had the TB job done, then they flushed the system & there may be an air bubble in the system causing the car to run a little hot.
kbunting
Apr 13, 2015 10:08 PM
lionel a6 2.8 v6 c4
Feb 10, 2014 05:07 AM
madridlover
Dec 4, 2011 12:15 PM
MauriSSio
Jan 9, 2008 08:51 AM
lacrosse22
Feb 10, 2006 09:34 PM
