A6 4.2 with 140k trans acting funny
Hello everyone,
My wonderfull 4.2 is starting tosurgebetween 4th and of 5th gear while driving at 45mph.The tach goes from 1500 to 2000 like a heartbeat. It alsoclunks downshifting to 1st at stoplights. I love the carand want to keep it, should I try a flush?
This you guys have helped me many times thank you!
RE: A6 4.2 with 140k trans acting funny
My 2.7 did this. I had it flushed and the problem didn't really go away. I talked to the dealer and they "flashed" the cumputer. No clue what flashing the computer involves but the problem went away. This isn't much but I hope it helps.
ORIGINAL: namymark
how long have you had the A6? I'm curious to know what repairs you've made because mine has 70K and I'm wondering what to expect from it.
If you were asking about my car with 140k on it I purchased it out of CA so it had never seen MI winters still looks new underneath with no relating muffler rot. I have not done any major repairs only the window fix and I replaced all the front end parts as it wore out a brand new set of tires in 6 mo. It was taking the inside edges off!! I just found last nite the rack has a small pop to it when you pull on the tire hard to the front it is stiff in the center and is not loose or wearing the tires at all so I think it is ok. Has anyone else had this problem?
ORIGINAL: kwmcfp
Thank you for the help! i wont waste my time I think I will live with it if it is not mechanical, was the flash expensive?
if your trans hasnt been flushed multiple times during its life it is BAD to flush it at 140 because is will blow apart and everything will become looser ... not recommended ... the bench flash might work tho... not sure how tho lol maybe reset something lazy ... also coudl change the shift code or get a chip to put it back in its place ... 140k on a v8 trans is pretty good ... cross your fingers for no rebuilt !!
