A6 4.2 Won't shift out of first
Old Jun 14, 2011 | 11:30 AM
gixxsta04's Avatar
Default A6 4.2 Won't shift out of first
I have already tried changing the output speed sensor and the wire harness that runs to it with no luck. Is my transmission bad? Battery was just about dead btw. I think that is where some of the electrical malfunction codes came from.
Address 01: Engine Labels: Redir Fail!
Controller: 4D0 907 558 S
Component: 4.2L V8/5V G 0008
Coding: 06652
Shop #: WSC 24102
3 Faults Found:
18098 - Malfunction Indication Light (K83): Electrical Malfunction
P1690 - 35-10 - - - Intermittent
18084 - EPC Warning Lamp (K132) Circuit: Electrical Malfunction
P1676 - 35-10 - - - Intermittent
18032 - MIL Request Signal Active (Check TCM for errors too!)
P1624 - 35-10 - - - Intermittent
Readiness: 0110 0101
Address 02: Auto Trans Labels: 01V-927-156.LBL
Controller: 4B0 927 156 BS
Component: AG5 01L 4.2l5V USA 1414
Coding: 00002
Shop #: WSC 00000
2 Faults Found:
17114 - Gear Ratio Monitoring: Incorrect Gear Ratio
P0730 - 35-00 - -
17105 - Transmission Output Speed Sensor (G195): Implausible Signal
P0721 - 35-00 --
Old Jun 18, 2011 | 08:05 AM
bob martin's Avatar
IIRC those are the codes you get when your torque convertor has gone south. Try a search for torque convertor and see what you can find.
Bob
ericp1.8T
Dec 18, 2008 10:55 PM
hkasturi
Oct 1, 2007 08:32 PM
02A43.0
May 28, 2007 03:53 PM
starting...
Feb 7, 2007 04:15 PM
MJ23AIRMW
Mar 12, 2006 12:14 PM
