A6 Avant rear deck light change?
Old May 13, 2007 | 02:05 PM
jlewis166's Avatar
Default A6 Avant rear deck light change?
I have a 2000 A6 Avant. One of the lights next to the license plate is not working. I have looked the situation over and I cannot figure out how to get at the bulb. Anyone have the information?
Thank you.
Old May 13, 2007 | 02:09 PM
techbod's Avatar
Default RE: A6 Avant rear deck light change?
is it a licence plate bulb or a main bulb like a rear light?
Old May 13, 2007 | 02:13 PM
jlewis166's Avatar
On the read deck are two red lights next to the license plate opening. The license plate lights are in the plate recess, above the plate. The lights I am referring to are flush with the rear deck and red when lit.
Old May 13, 2007 | 02:26 PM
techbod's Avatar
Removing and installing bulb carrier
Removing
Switch off ignition and remove ignition key.
Turn light switch to “0” position.
Remove luggage compartment side trim cover.
Left side of vehicle:
Take out vehicle tool kit.
Both sides (continued):
Unplug connector -1-.
Squeeze catches -arrows- and take bulb carrier -2- in direction of passenger compartment out of rear light.
Take bulbs out of holders.
Installing
Install in reverse order.
[IMG]local://upfiles/12092/7C098DFB1506401980958EFECAD0B6CC.jpg[/IMG]
[IMG]local://upfiles/12092/99BFFEC30E14430FAEB640D329471C97.jpg[/IMG]
[IMG]local://upfiles/12092/EBDA1604EC2F48F2BA2F646577A63045.jpg[/IMG]
Old May 13, 2007 | 05:49 PM
jlewis166's Avatar
Dave:
I think that is the stop and tail light carrier you have sent pictures of. On the Avant there are two read lights on each side of the license plate recess. Those are the light bulbs I need to replace. I can not see any way to access them either through the compartment that has the warning 'X' or the licesnse plate area.
Thank you for your advice so far.
Old May 13, 2007 | 07:16 PM
marko_tomas13's Avatar
To the OP:
Are you talking about the two small rectangular lights on either side of the license plate?
Can you describe when they're not working, if it is the case that only one works when you turn on the fog lights then that is normal as only one of the rear fogs is supposed to work.
Old May 14, 2007 | 02:15 AM
techbod's Avatar
Removing and installing trim panel for rear fog light and number plate light
Removing
Remove number plate.
Saloon:
Remove rear lid trim
Avant:
Remove rear lid lower trim
All models:
Turn left bulb carrier -1- anti-clockwise and right bulb carrier -2- clockwise.
Take out bulb carriers.
Screw out bolts and unscrew nuts -arrows-.
Unplug connector -3-.
Use flat screwdriver to press fasteners at operating levers -1- in -direction of arrow-.
Pull operating levers downwards out of handle mechanism -2-.
Take trim panel for rear fog light and number plate light out of rear lid.
Installing
Install in reverse order, paying attention to the following:
Before tightening bolts and nuts, align trim panel for rear light with rear lid contours (even shut lines).
Saloon:
Install rear lid trim .
Avant:
Install rear lid lower trim .
Tightening torque
Component
Nm
Trim panel for rear light to rear lid
[IMG]local://upfiles/12092/9ABBE54E6E73410DAFC3E95025AE1425.jpg[/IMG]
[IMG]local://upfiles/12092/910E4437EAA24C5DA499C69226AA923B.jpg[/IMG]
[IMG]local://upfiles/12092/5FC22DCDB2664C8491E03C7C08280756.jpg[/IMG]
Old May 14, 2007 | 02:17 AM
techbod's Avatar
missed one
[IMG]local://upfiles/12092/7DD2BECA48F141088AA2BD0957ECD942.jpg[/IMG]
Old May 14, 2007 | 03:38 AM
techbod's Avatar
just in case its the fog light
Removing and installing bulb carrier for rear fog light
Removing
Saloon:
Avant:
All models:
Turn left bulb carrier -1- anti-clockwise and right bulb carrier clockwise.
Screw bulb out of holder.
Installing
Saloon:
Avant:
[IMG]local://upfiles/12092/C25955E655DB415EA9B2CC3DD68B5B3C.jpg[/IMG]
Old May 14, 2007 | 05:57 AM
jlewis166's Avatar
DAve:\
Thank you very much. That is fabulous.
