A6 Interior Heating Problems
Hi all,
I have been having problems with the interior heating on my 1996 A6 2.6SE not getting hot enough (just lukewarm).
I took it to a speciaist today and they have diagnosed it as a blocked heater matrix.
The temp on the dial gets upto 90 degrees and stays there which is the normal temperature I believe.
The garage also said that it may have been caused by someone putting Rad Sticks in??? The reservoir is a murcky brown colour, possibly as a result of the said Rad Sticks.
They have advised first and foremost that a thorough flush-out may clear the blockage and restore the heaters to their former glory but as a result, may spring leaks in the system which were blocked by the Rad Sticks.
Is this a fair assumption or does anyone have any words of wisdom on this matter??
Thanks in advance
Wibers
Thanks in advance
Wibers
Someone probably mixed some of the wrong antifreeze with Audi G12-- It is known to form a sticky mess. I would attempt to flush the system with water a few times and then remove the heater hoses and try to run some water thru it to clean it out. I don't know if there is a control valve that you have to by pass. Maybe someone can help you with that part.
