a6 keyless
Old Dec 4, 2008 | 02:25 AM
afstud6900's Avatar
Banned
Default a6 keyless
ok so i took apart my keyless last night, replaced the battery and now the buttons wont work.. i tried the putting the key in the ignition and turning it to on and then off and that did nothing. so what next? i dont have a vag-com either so dont offer those options.
thanks.
Old Dec 4, 2008 | 10:14 AM
zippy_gg's Avatar
Not sure why you won't get a Vag-com. The cable sells for about $15.00 on eBay and you can use the freeware for many basic operations on your Audi.
Old Dec 4, 2008 | 10:27 PM
CosminTX's Avatar
thanks.
so.. if u only replace the batt in the remote , u should reprogram the fob with the second fob, one in ignition , one in the door.u don`t need vag for this, just have the second original key. if u don`t have the original , or any other key to do the 2 key process, than u should go to the dealer , or if u have the cars paper with the skc and 4no pin , u may program it yourself with vag-com , but vag-com , must be full version to access and do changes is major modules. the cable from ebay work too but u still need the licence for full version , or someone in your area with vag . good luck!
Old Dec 4, 2008 | 11:56 PM
hurricane860's Avatar
thanks.
mine did the same thing on my 99 a6 too. funny i was asking my brother why it wasnt working, he took the remote and hit the button and worked..im like WTF! How did you do that, hes like i just pressed the button lol...i guess you just keep clicking the dam thing until it works llol
Old Dec 5, 2008 | 12:15 AM
Jeffla's Avatar
1. Stick the key in the drivers door
2. lock the door manually
3. press the lock button on the keyfob
4. unlock the door manually
5. press the unlock button on the keyfob
6. remove key from door and it should work.
Only 2001(2) + cars need a vag-com to program their keyfobs. If you have more than one keyfob let me know and I will look up how to get them all to play together nicely. It might be unlock then lock in the directions above, don't remember.
Old Dec 5, 2008 | 01:16 AM
afstud6900's Avatar
Banned
ok so i figured out how to get it working... i put the key inside the door lock turn it to lock then unlock and then it works... i did i like 5 times to confirm it and it worked everytime.
thesponge
May 9, 2009 01:00 AM
audiudo
Oct 2, 2007 06:17 PM
vr4marine
Feb 13, 2007 08:39 PM
BLRzAUDI
Sep 29, 2006 07:08 PM
quattromond
Jun 17, 2006 01:38 AM
