A6 keys
Old Sep 11, 2005 | 01:55 AM
beefski's Avatar
Default A6 keys
I only have one key 4 my 96 a6 q w.
the locksmith i went to said the key had a chip and he could not dupl.
the key i have is the one with the small light.
he had a key to cut bu could not guarantee it would work.
it would be a $25 gamble
does anyone have any info?
there are also blanks avail on ebay.
thanks
Old Sep 11, 2005 | 02:11 AM
FootIntheGrille's Avatar
Default RE: A6 keys
I doupt it has a chip. My '00 A6 has no chip. I went to the dealer, $75 for the blank, $25 for the key to be cut. Bit of a ripper if you ask me, but no choice.
Old Sep 11, 2005 | 02:43 PM
misko's Avatar
Default RE: A6 keys
I am a locksmith and I looked up the key for your car. It seems that the key does have a transponder in it, but the car has no reciever. So a standard key will work.
Old Sep 11, 2005 | 04:44 PM
beefski's Avatar
Default RE: A6 keys
misco, thanks 4 the 411.
u r absol sure?
i will go 4 it. now ill get a couple cut.
thanks.
Old Sep 12, 2005 | 11:20 AM
misko's Avatar
Default RE: A6 keys
yes I am sure about the key. I use a program called Auto Smart, it gives me all the info on how to make a key and what is needed to do so. Just to mke sure I checked earlier years and some later ones. You can call some local lacksmiths, if they have the right key dupicator machine they will do it much cheaper. The key blank should not really cost more than $20 plus the cost to copy it. The copy is pricy because the machine goes for around $15K.
hope this helps
Old Sep 12, 2005 | 11:51 AM
beefski's Avatar
Default RE: A6 keys
yes it does help, next chance i get i will have the key cut.
thanks again for the info.
Old Sep 15, 2005 | 02:05 AM
kianoosh's Avatar
Default RE: A6 keys
Not sure if this works for you or not. When I got my A6 97 Q this summer, the guy had the newer generation of the key (switch blade style) with it. It's the one with the built in alarm, lock, unlock... switches on it. Dealer chrages about $200 for this (in CDN), but you can find a so called uncut one from ebay for about $40 and get it cut for perhaps a few bucks more. You'll have to program it to work with your car, but it may be a nice thing rather than a regular key. Make sure you know what you're buying though!
Just my two cents.
Kianoosh
Messiahlee
Jan 9, 2019 02:42 PM
ParadoxZero
Feb 14, 2014 09:39 AM
soccergk
9
May 4, 2009 09:12 PM
wanger727
Mar 30, 2009 03:08 AM
piloturco
Sep 10, 2006 11:07 PM
