A6 overheating
Old Apr 27, 2014 | 01:27 AM
frenchchris's Avatar
Default A6 overheating
Got an A6 1999 2.8 . Replaced timing belt ,water pump at 80000 . Car start to overheat at 120000 , spot some coolant on top of my block . Would like to know where the thermostat is located ? Thanks
Old May 10, 2014 | 08:46 PM
ImTheDevil's Avatar
Thermostat is behind a channeling plate on the passenger side front of the engine and should've been changed along with the timing by. Coolant on top of the block means a leak from something else. These t-stats are failsafes, meaning they stick open when they fail, so a bad t-stat shouldn't cause an overheat.
katcoota
Mar 8, 2009 11:25 AM
Sherman Banks
Aug 9, 2008 02:07 PM
Teutonic2.7T
Jul 3, 2008 11:50 AM
pete47
Apr 10, 2007 07:44 PM
