A6 questions
Old Jun 5, 2007 | 01:13 PM
Spaz's Avatar
Default A6 questions
I am in the market for either an S4 or an A6, I have about $15k to spend. What is considered to be the best A6 in that price range. From what I read it seems as thought the 2.7T is the most favorable A6. I do not plan on doing any mods to the car other than wheels and tires at some point, and maybe lower the car depending on the wheel size. So please give your opinions on the A6. Also would you prefer an S4 or an A6. The size of the car is not a factor. Thanks!
Old Jun 5, 2007 | 01:26 PM
Joeski's Avatar
Default RE: A6 questions
Well if it was me.....If I was only doing exterior mods, I would go with the 4.2. It is more reliable then the 2.7T. If your doing engine mods, the 2.7T is the hands down winner! They will tell you to stick with 18's on the A6 which I have no problem with although I went with 19's.
S4 or A6, once again, depends on what you want. The S4 is the staple car to modify. Its 2.7T motor is perfect for it, plus its a bit lighter and smaller. The A6 is larger, little more luxury and more comfortable.
Hope it helps!
OOOO
Old Jun 5, 2007 | 02:30 PM
Spaz's Avatar
Joeski, thanks for the reply.
Old Jun 5, 2007 | 04:01 PM
Joeski's Avatar
No Problem my friend!
OOOO
Old Jun 5, 2007 | 08:30 PM
Kevin's Avatar
If you don't plan on any engine mods, the 4.2 gets my vote.I also vote for the A6 over the S4. A used S4 has probably seen some agressive driving.
Old Jun 7, 2007 | 09:11 AM
Spaz's Avatar
Thanks Kevin!
mblayton
Jan 7, 2010 07:35 PM
playboy00786
May 31, 2008 06:37 PM
zchb9
May 20, 2006 01:29 PM
portwolf
May 18, 2006 03:27 PM
VolcanicBlackA4
May 18, 2006 02:11 PM
