A6 thermal Switch
Old Nov 15, 2006 | 08:51 PM
nexuspr's Avatar
Default A6 thermal Switch
Hi, I notice my A6 2000 2.8L , the cluster panel, ins't showing car's coolant temperature? always on low, sometimes it does show temperature, but most of the time , the gauge is always on low, I need to know is that a thermal switch bad reading?, cause Im most certainly shure it is, and if so, can someone tell me in what part of the engine I can find it so I can replace it , thanks.
Rene.
Old Nov 15, 2006 | 10:27 PM
mikehh's Avatar
Default RE: A6 thermal Switch
i have the same thing on my 2000 a6 2.8q avant...
let me know if anyone will have an answer to that...
Old Nov 18, 2006 | 06:09 PM
mpw2.7T's Avatar
Tech article from AudiWorld
This for an A4, but it should be similar for an A6.
A couple thoughts:
1) Make sure you have a replacement retainer clip - they're cheap and if the existing one is plastic, it may break on removal.
2) Make sure the old O-ring is removed before you install the new sensor. Someone on this forum spent a bunch of time trying to install the sensor only to find the old O-ring was still in there.
TRUK
Mar 2, 2009 11:54 AM
votblindub
Jan 2, 2008 09:49 AM
zectasy
Jun 10, 2007 09:51 PM
seattle_s4
Nov 10, 2005 04:46 AM
egolub
Aug 8, 2004 06:32 PM
