A6 Turn Signal Bulb
Old Aug 20, 2005 | 11:45 AM
cricha02's Avatar
Default A6 Turn Signal Bulb
How do you replace the front turn signal bulb on a 1999 A6... Something so simple, seems so complex ?
Old Aug 20, 2005 | 04:49 PM
europabluea6's Avatar
Default RE: A6 Turn Signal Bulb
The Indicator bulb holder is a bayonet type fixing, You just turn AC and out it comes. For the side where the air intake is you need to remove the pipe first by releasing the two screws on the front above the radiator. Good Luck! Europabluea6. PS mind the orange bulb coating doesn't fall off and drop into the lamp housing. Verrry fiddly to remove!
llove
Dec 3, 2012 09:22 PM
VB05
May 30, 2008 11:05 AM
Mr BitJazz
Nov 13, 2006 05:56 PM
jkd1226
Mar 5, 2006 07:29 PM
FezA4
Oct 15, 2005 05:50 AM
