front turn signal bulb replacement
Old Nov 13, 2006 | 12:11 AM
llove's Avatar
Default front turn signal bulb replacement
Am trying to sell my daughter's 2003 A4, and it has a bad right turn signal on front. Does one have to remove the whole headlight assembly to get to the bulb?
Old Nov 13, 2006 | 03:51 AM
Amze's Avatar
Default RE: front turn signal bulb replacement
What did she do to it?.. sigh
Old Nov 13, 2006 | 04:20 PM
kpatz's Avatar
You might be able to get the bulb out without removing the assembly (not sure how much room is back there offhand), but it's a lot easier to remove the assembly.
For the passenger side headlight, you'll have to remove the intake duct (2 screws, and it pops off). Then remove the two torx screws in front, and LOOSEN (don't remove) the two torxes behind the headlight. The assembly will pull right out.
Old Mar 31, 2007 | 11:56 PM
SILVERSVS's Avatar
This was helpful. I didn't realize the intake had to be removed for the second lower torx screw. I was only able to see one from the top.
Old Dec 7, 2011 | 07:30 AM
Pablo_Ottawa's Avatar
It`s best to remove the entire assembly. Not hard to do really. remove the air cleaner intake, 4 torx screws and it's out. no biggie.
Old Dec 3, 2012 | 09:22 PM
evgor@telus.net's Avatar
How to replace front turn signal 2007 Audi 4
jhsoccerodp
Aug 9, 2008 01:32 PM
wutafobbb
Apr 15, 2008 10:23 PM
Mr BitJazz
Nov 13, 2006 05:56 PM
jkd1226
Mar 5, 2006 07:29 PM
cricha02
Aug 20, 2005 04:49 PM
