A6Q Thermostat Replacement
Old Dec 10, 2009 | 01:55 PM
altonachrome's Avatar
Default A6Q Thermostat Replacement
Has anyone had the pleasure of replacing the thermostat on a 95 A6Q? Is it a fairly simple procedure or do you need to be a Russian gymnast to do it? Any tips or suggestions would be greatly appreciated!
Thx!
1995 A6Q
92,350K
Old Dec 13, 2009 | 10:15 PM
a6hcw's Avatar
Since the thermostat is behind the timing belt on the 2.8L V6 12 valve AFC engine, you need to be very careful that you don't get your timing off and destroy the engine. A cam alignment bar holds the cams in position and a crankshaft locking pin holds the crankshaft at top dead center when installing the timing belt. The BentleyPublishers.com Audi shop manual CD has more imformation.
Gary Knox
Jan 20, 2014 09:07 PM
gofaster
Feb 17, 2010 09:49 PM
ecriswell
Sep 2, 2006 11:01 PM
ChrisB
Feb 17, 2005 07:02 PM
A4izzy
Mar 9, 2004 05:29 PM
