ABS
Old May 3, 2007 | 02:21 PM
SLINEA6's Avatar
Default ABS
ok, i read that it comes on when you first start the car and you should hear a weird sound, sounds like metal scraping or hitting something else, this seems to be normal from whati read? I back my car out and turn the wheels into forward and change the shifterto Drive and then the sound happens, is that the ABS turning on? what a weird almost scary noise?
Old May 3, 2007 | 03:33 PM
auditech79's Avatar
Default RE: ABS
It probably is your ABS activating but it shouldn't un-less your doing an ABS stop. If its activating randomly there might be a problem with a wheel speed sensor or the brake light switch.
Old May 3, 2007 | 03:49 PM
SLINEA6's Avatar
Default RE: ABS
i have only heard it when i start the car and back up and then pull forward, it sounds like its right under the car in the engine area, no lights come on either, i just got the car and it had 33XXX on it, they also audi certified it as well...
Old May 3, 2007 | 04:32 PM
auditech79's Avatar
Default RE: ABS
Well s*** if its certified just take it in and pay your$50 deductible and let them worry about it. That goes for the wind noise as well. (previous thread)
